Old 03-25-2007, 02:38 AM   #1126
alright, thx anyway
tamiya123 is offline   Reply With Quote
Old 03-26-2007, 12:42 AM   #1127
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
is it "safe" to run the evo 5 without the gearbox covers on? (outdoor track, smooth concrete)
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 03-26-2007, 12:45 AM   #1128
RocketRacer's Avatar
i wouldn't advise it. you can be sure that some grit will get in there and cause excessive wear to the bevel gears. why do you want to run without the covers??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 03-26-2007, 12:47 AM   #1129
because every now and then i obviously check to see if the bevel gears are worn.......and it would be easier to check them without and covers on......
also, what is the difference between the Evo 5 one way gear (51255) and the evo 5 ball diff gear (51256)?
Castle Hill Raceway
Old 03-26-2007, 01:21 AM   #1130
don't be lazy just open 3 screws to check!!
the ball diff gear has the 3mm holes to accomadate the actual balls. and the one way gear has holes that you put screws through to mount onto the front oneway unit.
RocketRacer
Old 03-26-2007, 01:31 AM   #1131
can u use the ball diff gear in the front?
Castle Hill Raceway
Old 03-26-2007, 01:32 AM   #1132
only if you are running a ball diff in the front. i will not work on the oneway unit.
RocketRacer
Old 03-26-2007, 02:41 AM   #1133
and also should i grease the bevel/one way/ball diff gears?
Castle Hill Raceway
Old 03-26-2007, 03:32 AM   #1134
i run all the gears dry. less friction=freer drivetrain. you do get slightly more wear, not excessively though.
on the rear diff. use a dot of diff grease on each ball and a thin film on each diff plate.
RocketRacer
Old 03-26-2007, 04:10 AM   #1135
thanks RocketRacer , and does anyone have a link to David Juns Evo 5 stuff?
Cheers
Castle Hill Raceway
Old 03-26-2007, 07:31 AM   #1136
TryHard's Avatar
http://www.tamiyausa.com/articles/fe...article-id=226
there you go
Old 03-26-2007, 08:41 AM   #1137
Send a message via ICQ to rcnewb2004
I wish david jun actually followed up on the article... "come back in a couple weeks"... sigh... would have liked to know what he would say about the evo v.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 03-26-2007, 08:56 AM   #1138
here is my mods to fit maxamps 8000 in my evo V
my firt experience was not cool , i had a frontal crash and the battery did not handle it right, the upper 2 cells slided few milimeters to the front, i did put foam in the front down battery holder to portect of frontal crashes but because the foam ws only in the down part, the two upper cells slided , nothing serious as you can move them back but this thing could be avoid if maxamps guys buit it with double side tape between each cell i think
the alu plate is secured by only the boby clips, its enough to keep it tigh as there is no slop between battery and alu plate, i needed to unscrew the metal body clips holders a little bit to get the battery in
here you can see more pics
remember this mod is not secure completly , i need to figure out how avoid upper cells slipping on frontal crash , i put a couple of rubber bands around the post as you can see in second group of pictures, but it doesnt work also , i tested with second frontal crash LOL
the blue alu knucles are by SQUARE , they did it for evo IV but as you probably know they share same knucle so it fits just perfect,good news are they are light and very strong ( i crashed the car many times and they look just perfect) bad news are they are expensive .
theese one are cheaper, and maybe strongers as they are alloy ones
http://www.rcmart.com/catalog/produc...ducts_id=23174
or there are also knucles by TOPCAD i just daw them on rc-mart but looks like somebody bought the last stock because it is not showing up anymore , t was 8.5 dollars if i remember well
DrKucho is offline   Reply With Quote
Old 03-26-2007, 01:19 PM   #1139
Originally Posted by TryHard
thanks
Castle Hill Raceway
Old 03-27-2007, 01:51 AM   #1140
bender's Avatar
I think you've got that backwards. Less grease = less DRAG, which is totally unrelated to friction.
Running the gears without lubrication will mean they heat up more, creating MORE friction, which in turn reduces the efficiency of the car.
Remember, how long the transmission spins for has absolutely nothing to do with its overall efficiency. If free-spin was a true measure of efficiency, then we'd all be running shaft drives with dry ball bearings - as this would give the most free-spin. The reality is that running everything "dry" only increases heat and friction between any surfaces that are moving against each other (ie: bevel gears) and this is amplified as speed increases.
Lube the gears with Tamiya ceramic grease. This stuff is magic and reduces noise, friction, and wear.
I've lost count of the number of shaft drive owners who have put this stuff into their car and told me how much better it was
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
