Like Tree1Likes
Old 03-23-2007, 01:52 AM   #1111
pole_position's Avatar
Originally Posted by t4m1y4niac
guys, i'm using TB Evo 3 Surikarn...is there any Tamiya's Hop up for replacing the centre plastic brace for the upper deck (under the upper deck) with the aluminium one? please PM me, because i'm not regularly on line...thx guys..
Part #3455845 from TB Evo IV MS
pole_position is offline   Reply With Quote
Old 03-23-2007, 01:57 AM   #1112
Default Evo V diff joint and diff ring gear for Evo IV??
Has anyone tried to use the tried to fit in the entire Evo V diff joint and ring gear assembly into an Evo IV???
Is it good to fit in???
Advice anyone???
Thanks!
Old 03-23-2007, 10:13 AM   #1113
Trader Rating: 30 (100%+)
I had both the Evo IV & V at the same time and I can tell you that as long as you change the main diff gear, the Evo IV's diffs will fit in the Evo V. So my assumption would be that the Evo V diffs should fit in the Evo IV as long as you change the main diff gear to the Evo IV's. Also, you must check your gear mesh and make sure you shim it properly.
wrxnfx is offline   Reply With Quote
Old 03-24-2007, 02:21 PM   #1114
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
hey guys,
is there anyway to fix my stripped threads on my front bumper and body posts......there is nothing wrong with the screw but the plastic they screw into is no good..........they just never tighten and i have to re tighten them every race!
cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 03-24-2007, 02:26 PM   #1115
Originally Posted by surrealmaterial
hey guys,
cheers
i think is the contrary , the screws that came for that purpose are not the right one for plastics , they are good for metal threads but for plastic the thread is very small , change the screws for ones with bigger and sharper thread as the ones that came for tamiya plastic kits , that's what i did .
DrKucho is offline   Reply With Quote
Old 03-24-2007, 04:29 PM   #1116
hierog's Avatar
you could try longer screws too so that it goes higher up into the plastic, but really at this point you should just replace the parts
vic
hierog is offline   Reply With Quote
Old 03-24-2007, 04:35 PM   #1117
vic
longer is good too , but i dont think he needs to replace parts, i did had same issue , replacer the screws for the right ones and no more ploblems
Old 03-24-2007, 06:18 PM   #1118
alright thanks guys.........
Castle Hill Raceway
Old 03-24-2007, 08:07 PM   #1119
so has anyone got a chart that shows what gearing combinations are possible, in the evo 5?
Castle Hill Raceway
Old 03-24-2007, 08:11 PM   #1120
hierog's Avatar
go to www.gearchart.com. it will custom make you a cool cheat sheet for spur/pin combos
vic
Old 03-24-2007, 08:30 PM   #1121
thanks, but thats not quite what im after........im after a chart or something that shows you what spur/pinion can actually fit in the car.......because i know not all spur/pinion combinations fit because of the upper deck and motor mount.....
Castle Hill Raceway
Old 03-25-2007, 12:58 AM   #1122
i just changed to 48 pitch , maximum spur is 75 and smallr pinion is 17 , you have to file the inside part of spur hole of upper deck dough
Old 03-25-2007, 01:12 AM   #1123
Send a message via ICQ to rcnewb2004
can anyone give me the height difference between the upper and lower deck of the evo V? (I just want to know if something like a maxamps 8000mah will fit in the car)
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 03-25-2007, 01:28 AM   #1124
so with a 75 spur a 17 pinion is the smallest you can fit, so what is the largest pinion you can fit?
Castle Hill Raceway
Old 03-25-2007, 01:48 AM   #1125
i dont know, im not interested on that i run BL so i need large ratio
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
