Old 03-11-2007, 12:59 PM   #1096
peejay's Avatar
Originally Posted by rcnewb2004
sweet! thanks peejay!
What is the highest and lowest gearing achievable on the evo 5 without modifying upper and lower decks?
Dunno but read on
OK with the 0.4 module gears the combinations of spur/pinion were lifted from the Evo III/IV/5 manuals. I then used some maths to come up with 48dp spurs that have approximately the same diameter as the 04 spurs, and then some 48dp pinions to give FDRs approximately the same as the 04 gears.
I don't own an Evo so I cannot offer personal experience, but after reading so many posts about this ratio and that ratio and 04 (or 64dp) versus 48dp, I figured that there must be a relatively simple way, using simple mathematics, to make a comparison, and the pdf I posted is the result. I am sure that those who like to experiment will do so, so take it at face value and enjoy
Perhaps I should add E&OE at this point
Feedback on dud ratios or pinion spur combinations not in the tables that do work would be useful to update the tables.
HTH
peejay is offline   Reply With Quote
Old 03-11-2007, 04:54 PM   #1097
TryHard's Avatar
I think 100 is the biggest I've fitted... I'm pretty sure a 102 will poke through underneath the chassis, a a bit of chamfering of the upper deck holes (for security's sake).
HiH
Ed
Old 03-12-2007, 01:42 AM   #1098
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
HiH
Ed
do all those gearing ratios "fit" without hitting anything etc?
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 03-12-2007, 01:55 AM   #1099
TryHard's Avatar
pretty much. The 100 is close, the 102 closer still. I chamfered the edges of the top deck where the spur comes through, just to make sure.
HiH
Ed
Old 03-12-2007, 02:04 AM   #1100
ok what about the 94/48
Cheers
Castle Hill Raceway
Old 03-12-2007, 03:43 AM   #1101
bender's Avatar
Cheers
That should fit - it's the equivalent of 71/36 in 48dp.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 03-12-2007, 03:43 AM   #1102
TryHard's Avatar
94 fits fine.. although I haven't measured what the smallest pinion gear you can run is. Would have a guess at around 22/23, maybe 24.
HiH
Ed
Old 03-12-2007, 10:38 AM   #1103
Send a message via AIM to GuyIsDamGood
Default TB Evo 5 SET-UP
I`ve found a Perfect Set-Up for the Evo 5:
----------Aspalt Set-Up----------
Camber- Front: 0-Degree - Rear: 1-Degree
Caster- Front: 4-Degrees - Rear: 0
Toe- Front: 1 Toe-Out - Rear: 2 Toe-In
Droop- Front: 5mm - Rear: 5mm
Ride Height- Front: 5mm - Rear: 5mm
Shock Fluid- Front: Tamiya 400wt - Rear: Tamiya 400wt
Shock Piston- Front: 2 Hole - Rear: 2 Hole
Springs- Front: Yellow(Medium) - Rear: Yellow(Medium)
Swaybar- None
-Motor: 13-Turn
-Tires: Sorex 36R
-Gearing: 32-Pinion - 96-Spur
You can set-up your own Roll Center(Camber Link Shims) and Shock Mounting Positions.
Sorry; I don`t run on Carpet so I don`t have a Set-Up for it.
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 03-12-2007, 01:12 PM   #1104
ok because i have a 71/34 in it atm, and the pinion is VERY close to the upper deck..........
Castle Hill Raceway
Old 03-12-2007, 01:42 PM   #1105
bender's Avatar
You should try and use the biggest spur gear you can in a shaft drive, firstly because there is less chance of the pinion touching anything and secondly because you will be moving the motor further away from the centre of the car, which will balance the left/right weight distribution a little more evenly.
Jason W
Old 03-13-2007, 09:14 AM   #1106
Send a message via ICQ to rcnewb2004
the tb5 comes with 4 degrees caster as per instructions?
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 03-13-2007, 09:34 AM   #1107
yes but comes with 2 degree c hubs as well, 4 & 2 deg included in kit
DrKucho is offline   Reply With Quote
Old 03-16-2007, 08:32 AM   #1108
Default My 1st Race with the TB Evo 5
I was using(Racing with) My Old Set-Up1-Degree Front Toe-In, Front Droop: 6mm - Rear Droop 5mm). . . . .I was doing alright.....Until I hit a Barrier(very Lightly) on the Left Side of the Car.
-It was now pulling to the Right Side.
-I thought I killed the Left Aluminum Axle.
I went to to My Pit Area and decided to use My New Set-Up(I`ve Posted It Earlier).
-What a Difference. . . . .It doesn`t wander; It`s Better.....and I didn`t kill the Aluminum Axle.
What does this tell Us TB Evo 5 Owners?.....Be Careful. The Evo 5 Can`t really take Side Hits(anywhere near the Wheels).
I`ve had a Side Crash with My Pro 4 and NO DAMAGE.....I didn`t have to change anything after the crash.
I like the Evo 5 Diffs over the Pro 4 Diffs. Set the Diff(s) and You`re Good To Go.
The Evo 5 Steering is more Free over the Pro 4 Steering.
For some reason the Pro 4 feels Faster than the Evo 5. --I`ll do some Lap Tests with both Cars/Kits when the Weather Warms-Up again.....(It was Warm in New York City on Monday - Thursday. . . . .It`s Friday and it`s Snowing.)
Take Care
Old 03-16-2007, 10:08 AM   #1109
bxpitbull's Avatar
Default Sleepy23 makes custom outdrives
Sleepy23 makes custom outdrives per your need. Email him on this site or rcuniverse.com, tell him what you want and mail him the stock parts. He'll quote it out, let you know what cost is and mill it out of quality aluminum. Prices are very good and quality is top notch! Tell him the pitbull sent ya'!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 03-22-2007, 01:51 AM   #1110
anyone know the standard droop setup?
Castle Hill Raceway
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
