Like Tree1Likes
Old 03-03-2007, 01:07 AM   #1066
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
what about a 71/34.......will that fit?
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 03-03-2007, 11:36 AM   #1067
TryHard's Avatar
Originally Posted by veecee
Well seeing you saw some noticeable difference with the 1mm spacers, I'm going to give it a go on my MSX/RE. I'm still trying to chase more steering out of my car...
Well, I've done some measuring and this is what I've come up with.
Evo5;
Distance between steering posts and suspension blocks = 38mm
Wheelbase - Shims behind arms = 1.0mm
Ackerman Spacers = 1.0mm
Total = 40mm
MRE;
Distance between steering posts and suspension blocks = 37mm
Wheelbase - Shims behind arms = 3.5mm
Ackerman Spacers = 0.5mm
Total = 41mm
Basically, this shows to get the MRE and Evo similar, you need to run an extra 1mm behind the ackerman ball stud. (N.B. I'm using the hex-headed ball studs, which are 1mm shorter than the standard type).
So I'm going to run this next weekend, along with D/D on the front... should hopefully solve the mid-corner steering problem I had last time out.
HiH
Ed
Old 03-03-2007, 02:12 PM   #1068
Hey Guys,
just like to say that i just had my first race meet with my evo 5 and i was pretty impressed........my fastest ever time with my fk04 over 3-4months was 12.454 and in my second race in my evo 5 i did a 11.8
Castle Hill Raceway
Old 03-03-2007, 03:51 PM   #1069
veecee's Avatar
Trader Rating: 34 (100%+)
Evo5;
Total = 40mm
MRE;
Total = 41mm
HiH
Ed
Nice work Ed!
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 03-04-2007, 04:20 AM   #1070
Bro,
actually there is 1 pro setup reference but is in Jap, but most are readable except for the spring colour they use, any jap here want to translate?
http://www.tamiya.com/japan/rc/setting/evo5_init.pdf
Originally Posted by GuyIsDamGood
Hey Dtech and surrealmaterial; you guys are right(Dtech; I`ve never said you were wrong). But I`m a Lazy Guy. I don`t like to go over-board on a R.C. Car.....My Mini-Van.....just a little bit.
I`ll have to cut down the Plastic Battery Post and use a Small Snap Pin(Body Clip) on the Rear Post.
Hey surrealmaterial; I don`t use 48-Pitch Gears.....I can`t help you on that part.
I really don`t know what to set the Front and Rear Droop on. I have the Front Droop at 6 and the Rear Droop at 5.
-I can`t find any Pro Set-Up Tips for the Evo 5 at the Tamiya America site.
Anyone have any Droop Info?
Take Care
hoppie is offline   Reply With Quote
Old 03-04-2007, 05:26 AM   #1071
m3ndo5a's Avatar
Evo5;
Total = 40mm
MRE;
Total = 41mm
HiH
Ed
Got any pics? I am looking at my car like a space ship!
Thanks...
m3ndo5a is offline   Reply With Quote
Old 03-04-2007, 06:32 AM   #1072
TryHard's Avatar
Thanks...
Some pics for you
First two, shows the screws on both cars that I measured the distance between (rear two, steering posts, front two, suspension block).
Second two, show the ackerman spacers (red arrow), and wheelbase spacers (yellow arrow).
What I've done is assume all other measurements are equal, so effectively by adding thoose three variables together, I can figure out exactly the difference in ackerman between the two. A large total number means that the longitudinal difference between inner and outer l joint is larger... effectively putting the steering link at a greater angle.
Because the spacings are different on the two cars, the ackerman setting is different, which affects the way the car turns. I'm trying to get my MRE to handle as well as the evo on the rug, so hence why I've added spacers.
HiH
Ed
Tamiya TB Evolution V-dscf0011.jpg   Tamiya TB Evolution V-dscf0012.jpg   Tamiya TB Evolution V-dscf0016.jpg   Tamiya TB Evolution V-dscf0017.jpg
Old 03-04-2007, 10:59 AM   #1073
Rogier's Avatar
I have here a rolling Tamiya Evo 5 chassis for sale. The chassis is like new, only drove 2 times! Car is really as new! No electronics included! I can make pics for you if interested! Make me a nice offer and the car is yours!
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 03-05-2007, 07:40 AM   #1074
WC
WC's Avatar
Trader Rating: 28 (100%+)
-I was thinking about the TB Evo 3 Battery Plate. -It`s the same as the TB-02`s; just no printing.
EvoIII's battery strap is not same length as TB02's plastic strap,
the plastic one is longer - they are not interchangeable.
Can I assume TB02R's strap is same as the plastic one?
TA05 strap fits onto Evo5.
Wish Tamiya had supplied CF parts as standard for strap & bumper,
why did they stop doing it after EvoIII?!? Cheapskate costcutting...
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 03-05-2007, 09:38 AM   #1075
Trader Rating: 30 (100%+)
WC, I know that a TB02R strap fits as my friend has one on his Evo4 which I tried fitting onto my Evo5. If the Evo3 strap is different from the TB02R which I didn't think it was, then, it may not fit. The best bet is to just buy the lighweight set for the TA05 & use some o-rings or may your own spacers to use with the aluminum posts. This is what I am currently using on my Evo5 which used to be on my Evo4.
wrxnfx is offline   Reply With Quote
Old 03-05-2007, 07:35 PM   #1076
WC
WC's Avatar
yep eIII's strap is about 5-6mm shorter between holes.
(never could find this sparepart when I broke one of mine yrs ago.
Couldn't use a TB02 strap as its too long so I had to
get one custom-cut as a replacement.)
eIV uses TB02 strap, as does TA05.
Just tried TA05's CF strap and it fits eIV, does not fit eIII.
To use ladders in e5 gotta do some surgery to the stickpack cradle yea?
Cradle's mount holes are different to the similar part in eIII/eIV so
can't just borrow the eIII's non-cradle mounts onto the e5.
www.PandaGFX.com
www.MelbRC.org
Old 03-06-2007, 06:46 AM   #1077
Send a message via AIM to GuyIsDamGood
Hey wrxnfx and wc; Tamiya would have did us a favor if they made a Carbon Battery Plate and Carbon Bumper Plate(I would have paid more.....no problem).
-It looks like Tamiya doesn`t want to put any more Carbon on the Evo 5. They came up with the Plastic Battery Plate and Bumper Plate Set(49398 - 49399).
The TA05 Carbon Battery Plate is what we`ll have to settle for.
-But I`m not doing any hard changes on My Kits.
I need some Droop Set-Up info; anyone have any?
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 03-08-2007, 08:37 PM   #1078
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Looking for opinions:
Seriously thinking of purchasing a forum members EVO V setup, but I'm wondering how much better is it really over the EVO IV which I have now (and made the A-Main with at this past weekends TCS race).
Any comments are appreciated.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 03-08-2007, 10:23 PM   #1079
RocketRacer's Avatar
i used to run the Evo IV MS before i got the Evo 5. the cars are very very similar. it's easy to come out and say the Evo 5 is better 'cos it's newer. it boils down to how you can exploit the new layout of the Evo 5. i have managed to get myself alot faster with it than the MS.
i would say go for it! you are an A Main driver, seems like you will be able to take full advantage of the Evo 5!! do it!!
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 03-09-2007, 12:40 AM   #1080
TryHard's Avatar
Take Care
Indoor, Carpet, Rubbers - 6F, 4R
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
