Old 02-11-2007, 12:10 AM   #991
Justinian's Avatar
Does the Orion 4800 Platinum lipo fit in this car?? If so, do you secure it with servo tape and strapping tape? Do you need to add weight in order to balance the car with the lighter battery???
Justinian, Emperor and Roman God of Barrel-Rolls and Broken Parts...
________________________________________________
-Tamiya Evo V
-CRC T-Fource
-Losi XXX-S
-Darkside I-Force 10th scale pan car (under construction)
-Associated B4, T4
-Losi XXX-CR, XXX-4
"Evil will always triumph over good, because good is dumb!" :
-Dark Helmet, master of the Dark Side of the Shwartz......
Justinian is offline   Reply With Quote
Old 02-14-2007, 08:42 AM   #992
Send a message via AIM to GuyIsDamGood
Call Orion. They have test-Fitted their Li-Po Packs in just about every kit.
I believe there`s a list of kits those battery packs fit in on the Orion site.....?
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 02-14-2007, 10:42 AM   #993
fitting lipos into a shaft car is usually no problem. It's the belt cars that have trouble. The 4800 will fit in the EVO V
DOTMAN is offline   Reply With Quote
Old 02-15-2007, 06:49 AM   #994
TryHard's Avatar
Originally Posted by GuyIsDamGood
Cool set-up. Do you have a set-up for an Out-Door Track; somewhat grippy?
Anyone know the Item #s for the Blue and White Shock Springs?
Take Care
Hi Guy,
I'm afraid I've only run the Evo on the rug, so don't have an outdoor setup.
Having said that, I would have it simialr to that setup, except for no shims under the blocks, Blue (F) and yellow (R) springs with yellow roll bars, 40wt (F) and 35wt (R) oil in the shocks (with 3 hole pistons, and foam in top). Maybe some more rear toe-in if using a Mod or 19t motor, depending on setup.
Anyway, ran the Evo on carpet again this week, at a much tighter and lower grip track. Started out with the same setup as posted above, but changed it during the day. 2 things occured, detailed as follows.
1) it was taking well over two minutes to get the tires heated up, which ment I really struggled in the first few minutes, but when up to temp I was on the pace. Solved this by changing the spacers under the suspension block to 0.5mm (rather than 1mm), allowing the car to roll more. Worked a treat in the finals, and was strong for the full 5mins.
2) had a slightly oversteery balance all day, especially going into tight turns. I have a feeling I can solve this by running XA/D (2.5deg toe-in) on the rear.
Basically, was changing the setup from one that was suited to a large, high speed and grippy track to a smaller, tighter and less grippy one. Pretty happy with that setup I now, I can drive it fast and consistently, just a little fine tuning required.
Cheers
Ed
Old 02-16-2007, 12:24 AM   #995
found a problem yesterday
the rear uprights was compressing he bearings SO MUCH , so the wheels didnt spin freely, whith universals removed and trying to spin the wheel by hand , i can feel the BIG steps inside the ballbearings instead of soft and free movement, i dont know how this happened, i dont remember to have this issue when i built the car ...
to remove the bearing was a nightmare as they was so compressed, and they got lots of griding after runing with such stress, i had to do this to uprights
Dr Dremel made some room so the bearings can fit without compresion , wheels run free now...
anyone having same thing?
DrKucho is offline   Reply With Quote
Old 02-16-2007, 03:25 AM   #996
TryHard's Avatar
Check the hub for straightness.... I've had it before, and it turns out the hub was bent, compressing the outer edge of the bearing. It should be easy to spot, as the L section won't be at a 90 angle to the upright section.
Old 02-16-2007, 03:41 AM   #997
it doesnt look bent, and you have to mind both rear uprights had exactly the same issue , looks like they shrunk a little bit ....... is this possible? i mean , aluminium should not shrink , right?
Old 02-16-2007, 06:18 AM   #998
Send a message via ICQ to rcnewb2004
interesting... mine almost fall out of the uprights... maybe your upright/bearing has been damaged?
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 02-16-2007, 06:29 AM   #999
i dont think so
Old 02-16-2007, 06:40 PM   #1000
Hey TryHard; glad to see you`re having fun running on Carpet. I`ve tried it Once and I didn`t like it.....Too Tight.....Too many Crashes.....Ha Ha!
I won`t go back to Carpet Racing.
I don`t use Sway Bars on any of My R.C. Cars. I just try to get the right Shock Set-Up without them(Spring and/or Fluid).
Hey DrKucho; sounds like you have 2 Bent Rear Uprights or Messed-Up Bearings. . . . .Did you put any Thread-Lock near those Bearings in the Rear Uprights?
-I haven`t had that problem with My Evo 5.....yet. I would get NEW Rear Uprights and see what`s up.
Take Care
Take Care
Old 02-16-2007, 08:28 PM   #1001
clint's Avatar
Trader Rating: 22 (100%+)
Send a message via MSN to clint
Thought I would be the 1000th reply on this topic, I am still loving this car and finally after 5-6 months I just stripped my first one-way gear. not too shabby!!
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 02-16-2007, 08:32 PM   #1002
Hey guys...
Whats the biggest 48pitch spur that fits on this car?
Whats the final drive ratio (FDR)?
cheers...
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 02-16-2007, 08:45 PM   #1003
RocketRacer's Avatar
FDR is 2.437. i am not sure what the biggest 48dp spur is but i know you can squeeze in a 100T 64dp spur in. hope that helps.
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 02-18-2007, 12:43 PM   #1004
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Hey Guys,
At the moment i have an Xray t1 fk04 and am thinking of getting an Evo 5, although will this car handle/perform better than my current car racing in stock on smooth concrete, medium temperatures?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 02-19-2007, 01:39 AM   #1005
anyone?
Castle Hill Raceway
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
