Old 12-10-2006, 02:33 PM   #916
clint's Avatar
Trader Rating: 22 (100%+)
Send a message via MSN to clint
I hate to say it but I put the xray carbon strap on mine.
Works great just had to drill 2 holes.
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 12-10-2006, 03:57 PM   #917
cheehtae's Avatar
Trader Rating: 15 (100%+)
PIX?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-12-2006, 04:12 PM   #918
Hoggy's Avatar
Trader Rating: 26 (100%+)
Hey guys, just incase you didnt know
RCmart have clear diff covers for sale
http://www.rcmart.com/catalog/produc...ducts_id=21352
Hoggy is offline   Reply With Quote
Old 12-12-2006, 05:22 PM   #919
clint's Avatar
here are some pics..
Tamiya TB Evolution V-picture-438.jpg   Tamiya TB Evolution V-picture-439.jpg   Tamiya TB Evolution V-picture-440.jpg   Tamiya TB Evolution V-picture-441.jpg
Old 12-12-2006, 08:01 PM   #920
cheehtae's Avatar
Nice , even the PJ is nice
Old 12-12-2006, 08:28 PM   #921
clint's Avatar
thanks...damn I love this car.
Old 12-18-2006, 09:21 PM   #922
agp
does any1 know if 48mm swing shaft fits into this chassis? i have bought wrong swing shaft for my ta05. though of swaping it with my evo5. so the 46mm shaft goes to my ta05 and 48mm shaft goes to my evo.
agp is offline   Reply With Quote
Old 12-19-2006, 09:29 AM   #923
bxpitbull's Avatar
Default How does the Evo V drive
Compared to the Pro 4 and any of the high end belt cars (which I think are lame, but thats just me), how does the Evo V drive/handle? It is one sweet looking ride and I have to give you Tamiya boys your props for keeping shaft alive.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 12-19-2006, 06:58 PM   #924
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Talking
i might be wrong but i think it might not fit if the EVO 5 is using reversible SHORT suspension arms but if its the LONG suspension arms it might fit, better double check just to be sure
buboy28 is offline   Reply With Quote
Old 12-20-2006, 05:38 AM   #925
TryHard's Avatar
Personally, I find the Evo5 to handle pretty darn good. Have to admit, it's never felt as settled on the track as my MSX/MRE has... but then again the MSX/MRE never punched out the corners like the Evo5 does
I'm really loving the car at the moment... apart from one thing, its appitite for spur gears Hopefully I've now solved that problem, by sanding the back of the motor mount... looks awful, but should do the trick.
Cheers
Ed
Old 12-20-2006, 06:00 AM   #926
Send a message via ICQ to rcnewb2004
sanding back the motor mount? what's eating the spur gear? Got a pic? i am just a curious newb!
rcnewb2004 is offline   Reply With Quote
Old 12-20-2006, 06:53 AM   #927
TryHard's Avatar
Basically, I just roughend up the motor mount to get it to grip the motor better... I've lost about 7 or 8 spurs on the car in less than 6 months, (verus 1 in 3yrs on the 415) simply as the motor has moved following a large hit.
I'm hoping that this should solve that particular problem.
Good thing is I have a spur change down to about 3mins or so now... Theres even no need to remove the rear diff...
Ed
Old 12-20-2006, 08:06 AM   #928
Ed
3 minutes spur change? we definitly need pics of your mod man!
DrKucho is offline   Reply With Quote
Old 12-20-2006, 08:32 AM   #929
TryHard's Avatar
No mods needed, just a Hudy ball end hex driver...
Basically, take the top deck off, and undo your motor.
Remove front drive cup pin, then slightly flex the chassis to pop the centre shaft out of the front drive cup (it also needs to be as far back in the rear drive cup as possible). Then pop the pin out of the rear drive cup, slide off the spacers, and remove the motor mount.
Now the clever bit... take your ball headed wrench, slide it under the rear shock tower, between the uppr bulkheads, you can just get to the screws holding the spur gear to the mount this way .
Undo the two screws, pop the spurmount off, and you now have enough play to remove the spur gear itself (just make sure you catch all your spacers, and the spur mount pin).
Slid your new spur on, then the mount, line it up, and re-screw... then reverse the rest.
Clever eh...
Old 12-20-2006, 08:39 AM   #930
Is ur spur getting chewed up because of crashes? (no offense, but I am just curious)... or because u are running mod as well? I run 19T and haven't lost a spur yet. I am using TIR 64p pinion. (and its not that i don't crash... but because I am a parking lot racer at best, there isn't anything much to hit!)
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
