Like Tree1Likes
Old 11-23-2006, 03:43 PM   #886
Nautilian's Avatar
yup sent an e-mail as well. The sooner a spool becomes available the better
Nautilian is offline   Reply With Quote
Old 11-24-2006, 03:41 AM   #887
Hoggy's Avatar
Trader Rating: 26 (100%+)
here here
Hoggy is offline   Reply With Quote
Old 11-27-2006, 02:59 PM   #888
TryHard's Avatar
Hey guys,
Here's the setup i ended up with following the past weekend. It's a fair bit different to the stock setup, but handles really well.
Carpet Wars Round1 setup
Cheers
Ed
Old 12-01-2006, 02:52 AM   #889
OleC's Avatar
Thanks cheehtae. I'll see how it works on our track.
I use a spool (think it's a EVO IV, with TA-05 spool steel outdrives) in my current setup, but I think a diff might be better...
Our track is very bumpy though. So any pointers with that in mind is appreciated
Also, the foams you use are not available here. So we use foams for nitro touring (35-42 shore 26mm). I have no idea how grip is in them compared to e.g. Jaco...
OleC is offline   Reply With Quote
Old 12-01-2006, 03:08 AM   #890
TryHard's Avatar
right guys, question.... How has there servo horn setup as per the manual (offset) and who has it upright?
I was looking over this last night, and can't really figure out the reason for having it offset. I find it easier to have the horn upright, as this gives equal throw each side.... opinions?
Old 12-01-2006, 04:09 AM   #891
bender's Avatar
The way the manual has it (slightly angled) is correct.
Whilst you are correct in saying that you'll get equal servo throw with the horn upright, this doesn't equate to equal steering throw because of the difference in angles between when the horn is moved towards the centre of the car (pushing the linkage away from the pivot point and down from above), and when the horn is moved away from the centre of the car (pulling the linkage away from the pivot point and up from above)
It's alot easier to see than it is to describe
Basically, the servo-horn / bellcrank movement ratio is more proportional when the horn is moving towards the bellcranks compared to if it's moving away from the bellcranks.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 12-01-2006, 04:28 AM   #892
in addition if you put it upright i think you cant get the full stering range of one side cause the servo horn hits something before reach the expected end of travel
DrKucho is offline   Reply With Quote
Old 12-01-2006, 07:03 AM   #893
TryHard's Avatar
Ok, understand that.... effectivly, your trying to get the centre point of the steering at the tangent of the servo horn...
So why on the MRE do the instructions suggest upright, given it's a similar steering system?
I assume that it's simply because the steering is actually mounted higher (to clear the belt), with a vertical ball stud... and hence the link is at a flatter angle to start.
The reason I ask, is that I think something was slightly up with my car at the end of the meeting last week, in that it would turn nicely left, but struggle on right hander's. Spent a while last night playing around with the steering setup, and now have it slightly off centre (not as much as in the manual though), with equal steering throw side to side (measured on the toe gauges).
Cheers
Ed
Old 12-01-2006, 01:43 PM   #894
cheehtae's Avatar
Trader Rating: 15 (100%+)
I think you'll be fine with the foam tires your using, I use to run a speedmind foam on my TA05 (and ithink it's for nitro), for bumpy tracks I would position my shock angle more upright, Guys any comment for a bumpy track on foams.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-03-2006, 12:06 AM   #895
Hoggy's Avatar
So an EVO IV Spool works?? i was under the impression it doesent!
What do u need to make it work?
Old 12-03-2006, 03:39 AM   #896
BrainTeased's Avatar
oh the evo 4 spool works on evo 5? i didnt know that
does the evo 5 diff gear fit onto the evo 4 spool with no modifications?
also how do those couplings / outdrives fit onto the spool
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-03-2006, 04:01 AM   #897
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
just put the evo 5 ring gear on evo 4 spool , you have a evo5 spool
straight change that`s it
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 12-04-2006, 01:01 AM   #898
thanks for the confirmation jolly
Old 12-04-2006, 01:12 AM   #899
akuhon's Avatar
Default TB EVO5 Mini
Some one has done the conversion :
TB EVO 5 Mini Chassis
Enjoy ....
akuhon is offline   Reply With Quote
Old 12-04-2006, 02:50 AM   #900
veecee's Avatar
Trader Rating: 34 (100%+)
Hot Damn, thats nuts!!! Post a link please!!!
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
