Tamiya TB Evolution V
#871
Originally Posted by Hebiki
does anyone have insider information on whether or not Tamiya will release a spool for the evoV?
We do have a TB Evo5 designed and scheduled for production but we need more market research before we get the final go ahead.
BTW, their spool (with alloy outdrives) and diff halves for the 415 are top quality, so pretty sure one for the Evo would be good too.
#872
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
@Edd
if i put 2 o-rings in the top of my shock instead of the pink bushing
what am i getting
cheers big ears
PS;;if you are there on sunday i`ll be buying you drinks for a chat by the way (so be warned & bring a chair
what am i getting
cheers big ears
#873
Originally Posted by MR JOLLY
@Edd
what am i getting
cheers big ears
PS;;if you are there on sunday i`ll be buying you drinks for a chat by the way (so be warned : & bring a chair )
what am i getting
cheers big ears
O-rings in shocks, more pack I believe. You effectively puch the diaprahm (sp?) into the oil, making it more resistant to loading. Makes the shocks more responsive.
Personally, I've been using my shocks built as Mr Spashett advised me. 3hole/60wt/no foam or o-ring. Makes for a smooth shock, that helps stabilise the car on carpet. Outdoors, I reckon the O-rings might be a good call...
HiH
Ed
#874
Hi guys,
Im looking for a good base setup for the EVO V on carpet with foams (19T).
I've been looking around for a while for this, but without any luck...
#875
Originally Posted by OleC
Hi guys,
white springs front
maroon springs rear
4.5 front height
5 rear
droop 4 for f/r
I still use a oneway and it's working for me
#876
Originally Posted by TryHard
Oh and followed Mr Jun's advice on the Tamiya USA website, happily got the drivetrain spinning for 15seconds after a quick spin, and it's only get freeer as the new bearings start to break in more.
Cheers
Ed
Cheers
Ed
I had a search around for David Jun's bearing advise. Are you referring to cleaning out the lube and re-oiling? If something different any chance of a link please.
Cheers
Terry
#877
The best I could get my AEast 2005 SD to spin with wheels on was 39 secs.
you got some more work to do fellas!
#878
So c'mon Rob, what's the secret of making your spin freely, please........................
#879
degrease the bearings fully, 1 drop of the lightest oil you can find. I use Zubak speed lube and make sure the bearings do not bind up or are pinched by any other part/housing. Thats it
#880
Originally Posted by terryh
Nice
4-5 post`s rob in a couple of days blimey we are hounered
#881
Cheers Lolly, working nights now so need to traul the web just to stay awake.....
#882
Originally Posted by cheehtae
set-up as per manual
white springs front
maroon springs rear
4.5 front height
5 rear
droop 4 for f/r
white springs front
maroon springs rear
4.5 front height
5 rear
droop 4 for f/r
#883
it's for carpet with foam tires xxpinkorange and xxpink, itried running gray in rear and maroon in front but car was too snappy, also both maroons works well too. also no stabilizer bars on the rear and still using just the stock bars in the front, you might want to position your rear shocks four holes from rear "if" your track set up is smooth.
Originally Posted by Juan Aveytia
Why would you run a softer spring in the front?
#884
