Old 11-09-2006, 06:54 AM   #856
Hey guys.. just want some quick information so I don't have to search through heaps of pages...
Does anyone make a steel or alloy diff or bevel gear for the evo 5 yet? (to prevent striped front diff gears)
Anyone know a good place to pick up an evo 5 (looking to get 1 but would rather get 2 for spares).
Cheers...
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 11-09-2006, 11:33 AM   #857
TryHard's Avatar
@RR... 27t at the moment, although going to be using it in 19t later this month
@rcnewb2004... I understand it's best to not flush out ceramics from new, as they naturally throw out greese, free up over time. Although like anything with a surface contact, a bit of light lubing will help when beyond this stage.
And with regard to the free spin thing... it's more important in stock, where your looking for as high efficiency as possible. The freeer you can make the drivetrain, the easier it will be for the car to accelerate. Plus it gives good bragging rights ...
@Nautilian... The spacers are placed underneath the suspension blocks, and raise the roll centre. It's a coarser adjustment than adjusting the rc on the camber links. Obviously, the thicker the spacers, the higher the rc.
HiH
Ed
Old 11-09-2006, 10:57 PM   #858
RocketRacer's Avatar
@ TryHard. i have a few more questions.
1. What 27T motor are you running?
2. what kind of rollout do you use for your track?
3. are you running rubber or foams?
4. what's your setup like?
thanks
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 11-10-2006, 12:48 AM   #859
bender's Avatar
AFAIK no-one has released any optional gears yet. Tamiya have displayed the car with some white gears and some hard-andozed looking alloy gears but neither has been released.
I stripped my first front bevel gear a few weeks ago running 19T - my car had done about 11 race meetings.
I completely stripped 2 teeth from the front bevel gear during qualifying, I had no spares, so just shimmed it up pretty tight and it lasted for the 3 A-Mains
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 11-10-2006, 02:34 AM   #860
TryHard's Avatar
thanks
1) EA Motorsports CO27
2) geared at 96spur 30/31 pinion, reasonable sized indoor track (varies each week, but last time was 11second laps)
3) Rubber tyres (Vtec 24R)
4) not far off stock... actually thats a bit of a lie. I'll note it down tonight and post it up... although do note, I have things I'm still trying on the car to get it nailed. Having said that, it's still been good enough for me to TQ and win the past two clubs meets I've been too
HiH
Ed
Old 11-10-2006, 02:47 AM   #861
Nathan Parker's Avatar
HiH
Ed
You been Racing on your own again then ED
Nathan Parker is offline   Reply With Quote
Old 11-10-2006, 02:57 AM   #862
HiH
Ed
thanks for that Ed. i look forward to checking your setup. compared to your 415 how do you rate the Evo 5?
RocketRacer
Old 11-10-2006, 03:29 AM   #863
TryHard's Avatar
TBH, it's been a while since I ran the 415 (over 2 months now), but from memory I did find the 415 smoother...the evo seems more snappy. But both are quick cars.
Hopefully I'll get the new chassis for my MRE sorted in the next few weeks, so I can do a back to back with them.
Cheers
Ed
Old 11-10-2006, 03:36 AM   #864
Holmenkollen's Avatar
I drive modified and there´s a big difference between the Evo V and 415. A lot more "punch" in the Evo V due to the very free drivetrain. This also makes the car harder to drive. With a 27 or 19 turn motor the car is one of the best chassis around. If you drive mod go for belt.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 11-10-2006, 03:44 AM   #865
BrainTeased's Avatar
mines 15 sec with wheels ON. Grab the rear wheels, and spin as hard as possible... or just grab a front one and spin the drivetrain backwards (the front oneway helps here... locks up nicely being spun backwards ).
HiH
Ed
thanks for clearing that up Tryhard, others have said 15 secs wheels off which got me puzzled lol...
i must say though with wheels off my previous AE tc4 seemed to spool up alot free-er
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 11-15-2006, 09:48 AM   #866
Send a message via ICQ to rcnewb2004
rcmodel has the new transparent plastic covers for sale, but the gear covers are exactly the same. At least this way we can see if there is dust inside very quickly.
rcnewb2004 is offline   Reply With Quote
Old 11-15-2006, 11:04 AM   #867
Hebiki's Avatar
Trader Rating: 26 (100%+)
does anyone have insider information on whether or not Tamiya will release a spool for the evoV?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-18-2006, 07:52 PM   #868
drew85's Avatar
Has anyone else had any problem with there steering not being able to go to full lock? It goes to the right full and then some. I have the radio turned up all the way, dual rates and epa and still it come short. I tried moving the ball stud on the knuckle to the inside hole and it closer but its really buging me. I like to set it to full and turn it down so I know its the same on both sides.
drew85 is offline   Reply With Quote
Old 11-18-2006, 11:00 PM   #869
drew85's Avatar
OK i just tried it with my m8 and I still can't get full, the m8 will let me go higher but the servo will not go anymore and the KO will let it go further but only to the right!!
Old 11-19-2006, 05:45 AM   #870
cheehtae's Avatar
Trader Rating: 15 (100%+)
did you cut the servo as per intsructions or are u using a diff. kind, ckeck if it's hitting something or maybe yyour TB's are not of the same lenght.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
