Like Tree1Likes
Old 10-31-2006, 09:30 AM   #781
RocketRacer's Avatar
i guess that's the price you pay for racing a $350 chassis in a parking lot!
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 10-31-2006, 09:36 AM   #782
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by rcnewb2004
I just feel this diff cover problem should not be be a "suck it up and live with it" problem.
And since when am i a `SUCK UP` person
seriuosly i have had no probs with the diffs being open nor have i had any probs with gear stripping with poor meshing
after years off racing & building & things are built right then there is no problem
my biggest grip with a car this expensive , is being given a cheap shot spanner for the turnbuckles ,why not the proper blue Tamiya one they do
coz every time i use that poxy spanner some more blue come`s off
Me No suck up to any one
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-31-2006, 10:58 AM   #783
Nautilian's Avatar
Sounds like it is time to upgrade to some titanium turnbuckles, they do it on purpose so that you scratch and mangle that metal so that you think @%#$%@# HOT CAR, CR#P TURNIES... MUST FIX. I am quite suprised though that you have not bent any alu. turnbuckles though.
On a side note, do you guys put joint grease between your diff gear/crown and oneway gear/crown? Or do you leave those gears alone when lubing? Reason I ask is that I have heard that adding lube there adds drag. Can anybody point me in the right direction?
Naut
Nautilian is offline   Reply With Quote
Old 10-31-2006, 11:57 AM   #784
MR JOLLY's Avatar
Naut
Bending & Breaking go hand in hand with How Hard & How Often you crash the poor car
i don`t crash much ,a few hard hit`s ,but no bent or broken bits
lube gears
No. end off ,attracts dirt & shit & that alone is enough to say No to lubing gears
Old 10-31-2006, 03:27 PM   #785
Send a message via ICQ to rcnewb2004
First I would apologize for my "suck it up" comment to MRJOLLY. I did not think you were lying when you said everything was alright.
I would rephrase this problem as one that could be fixed, so why not fix it? why is your evo5 up for grabs?
rcnewb2004 is offline   Reply With Quote
Old 10-31-2006, 04:01 PM   #786
i just want to know how this car compares to the pro 4 performance wise
C_Suzuki is offline   Reply With Quote
Old 10-31-2006, 08:24 PM   #787
drew85's Avatar
Driver....
drew85 is offline   Reply With Quote
Old 10-31-2006, 09:59 PM   #788
lube gears
Definitely. stay away form the pipes or boards and nothing is going to break or bend, unless some backmarkers decide to take you out. i have had a few hits on both my Evo 5's but nothing bent or broken yet!
i also run the gears in the front and rear gearboxes dry. you will also notice that tends to pick up less dust than when you lube it.
@ C_Suzuki. the cars are very similar, but there are many factors that affect the performnace of a car. if we don't take any of the factors into consideration, i would say that the cars are almost identical performance wise, the Evo5 has bit of advantage in that it has a lower CG and better steering system.
RocketRacer
Old 10-31-2006, 11:49 PM   #789
MR JOLLY's Avatar
staright up if there was a prob with the car like the covers i`ll be there by your side ,but i have no probs like the meshing bit aswell
also i can`t be brought on the cheap ,
i have 2 cars evo 5 is going also health probs (shaking in the hands mainley) & this is very frustrating when i`m up front or on pace & then it starts
something is being done untill then it might aswell go
Old 11-01-2006, 01:47 AM   #790
hmm... i didn't mean to pry into your personals (i thought there maybe something wrong w/ the car, so you let go of it)
sad to hear about the hands.... I hope everything will be alright MR JOLLY.
Old 11-01-2006, 07:16 AM   #791
MR JOLLY's Avatar
if i didn`t answer honestly i would of lied
usually when some one sells a car for one reason or another
crap.breaks easily ,hard to work on ,fed up
me it`s just sitting there rotting away .
Old 11-01-2006, 09:03 AM   #792
Send a message via AIM to GuyIsDamGood
Hey TB Evo 5 Guys; Thanks for the Info.....
I`ve had this Steering Problem with My Pro 4. I`ve worked it out by using New Tires, giving it 1-Degree of Front Toe-In and installing a Front Ball Diff(Front Diff Tighter than the Rear Diff).
-It runs Really Well now.
On My TB Evo 5; I was using used tires and No Front Toe-In. But the Front Diff is a little tighter than the Rear.
--I`ll look at the Shocks and see if I`ve made a bad set-up there.
About the Front Toe-In: In R.C. Car Action(July - page 66); it says give your car 1.5-Degrees of Toe-In if your car doesn`t run straight. . . . .and check the Servo Saver.
-My TB Evo 5 will run straight only about 10-Feet past me and then it will lose it.
I`ll see if I can fix the problem later today.....?
I`ve said it before; If you sweep the Track - Street - Surface before you run your car on it.....it wouldn`t be very dirty.
Take Care.
GuyIsDamGood is offline   Reply With Quote
Old 11-01-2006, 10:55 AM   #793
two more things to check on steering. Check that the servo saver has no play in it. I had one that didn't fit quite right and would move under load. Also, check your radio steering wheel. I had problem getting my car to track straight and found that my steering wheel wasn't returning to neutral out of a turn. It was so small I didn't notice, but i cleaned my steering wheel bearing on the transmitter and tightened the wheel spring slightly and the problem went away.
DOTMAN is offline   Reply With Quote
Old 11-01-2006, 10:14 PM   #794
cyber3d's Avatar
With the proper shimming (everywhere!) how much slop do you have in the front wheels. What I mean is: does your toe and camber slop equal +/- 0.5 degrees (total of 1 degree) as mine does?
cyber3d is offline   Reply With Quote
Old 11-01-2006, 11:16 PM   #795
Nautilian's Avatar
How do you guys know you have shimmed something correctly. For example when you shim your rear diff, do you want to eliminate most of the play in the back but leave enough for the diff to spin freely? Or am I getting shimming completely wrong?
Naut
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
