Old 10-21-2006, 03:04 AM   #736
Nautilian's Avatar
I have solved this problem by taking gasket material and cutting a shape of the diff covers out, I use a 300 gasket, it works perfectly where no dust gets in since the material has a small compression factor and works 100% for me. You usually see this being used between Nitro engines and the exhaust connector to ensure a good seal.
I will put some photos up to show you guys if you want.
Naut
Nautilian is offline   Reply With Quote
Old 10-21-2006, 03:39 AM   #737
Send a message via ICQ to rcnewb2004
pics pls
rcnewb2004 is offline   Reply With Quote
Old 10-21-2006, 03:59 AM   #738
gasket matherial? whats that? can you give us some links to web shops?
DrKucho is offline   Reply With Quote
Old 10-21-2006, 04:28 AM   #739
BrainTeased's Avatar
you can actually get these gaskets at a automotive outlet. ask for gasket paper and they will show you a range of thicknesses and different materials. all you do then is cut them up to whatever shape you want.
great idea naut!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-21-2006, 04:48 AM   #740
i need to know what it is to get a translation to spanish ....
Old 10-21-2006, 08:54 AM   #741
remember!!! send us pictures Nautilian!
Old 10-22-2006, 12:52 PM   #742
Nautilian's Avatar
Pics will be on the way, I just have to get my digi camera out and take some shots!
On a side note, does anybody know if the EVO 4 direct spool will fit on the evo 5? Here is a link to the one I want to use: http://www.speedtechrc.com/store/ebp...id=276&id=5256
ALSO, can one put the Evo 4 suspension mounts on the EVO 5, or would the TRF415 suspension mounts work?
If anybody has any other ideas, feel free to give their suggestions!
Naut
Old 10-22-2006, 04:21 PM   #743
paitently awaiting your pictures.
check the last page... i donot own an EVO 4, but i think it has been posted before that the evo 4 spool will fit the evo 5.
Old 10-22-2006, 10:30 PM   #744
Naut
The EVO4 spool won't work with the EVO5. Suspension mounts, If your referring to the blocks like A, B and so on. All the blocks are interchangeable with any Tamiya car that use's blocks to hold the hinge pins in place.
Juan Aveytia is offline   Reply With Quote
Old 10-23-2006, 02:26 AM   #745
Holmenkollen's Avatar
It will work. Just put the Evo V one-way gear on it and use the Evo V bearings.
Shim it right.
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-24-2006, 08:03 AM   #746
Send a message via AIM to GuyIsDamGood
Hey TB Evo 5 Guys.
I`ve recieved My TB EVo 5 last week(built it) and it`s a Nice Kit.
It was easy to build and it comes with a Really Nice Aluminum Motor Heat-Sink.
But those Diff Covers; I thought I would be able to seal those things.....I was wrong. I`m worried about running it on My Street Test Track. I`ll have to sweep and Mop it.....Ha Ha!
For the price of the kit($435.00); I thought they would have made better Diff Covers.
Take Care.
GuyIsDamGood is offline   Reply With Quote
Old 10-24-2006, 03:07 PM   #747
Nautilian's Avatar
Hi guys,
Sorry I have not put up any pictures, I am in the process of rebuilding my Evo V, once this is done you will get as many pics as you want!
I have a quick question! I am getting ready to do a full bearing clean on my kit, however, I do not know how to approach the cleaning of the bearings in the steering arms and the steering bridge. Must I leave those alone, yank the bearings out or just clean them as they are and apply bearing oil just like the rest?
I also read when David Jun did his Evo V he left the 2x 850 bearings, why did he not do his rear diff bearings? Should I leave the thrust bearing out of the mix?
Link to article: http://www.tamiyausa.com/articles/fe...article-id=226
Thanks a mil
Naut
Old 10-24-2006, 11:38 PM   #748
RocketRacer's Avatar
the nbearings in the steering arms and bridge are pressed in, if i am not mistaken. i think taking them out might be risky 'cos i might be a bit difficult to re-seat them perfectly again.
just a thought.
do you run the front and rear bevel gears dry or lubed??
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 10-25-2006, 01:21 AM   #749
Nautilian's Avatar
When I built the Evo for the first time I ran them lubed (book spec), but I think this time I am going to put them in clean as I know this will reduce drag on the parts. I just need to find out about the bearings before I can actually go any further
Naut
Old 10-25-2006, 01:27 AM   #750
sorry i couldn't be of more help Naut. i am sure someone give you a better answer
have you run any of the previous Evo chassis'?
RocketRacer
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
