Old 10-13-2006, 04:46 AM   #691
BrainTeased's Avatar
Originally Posted by TryHard
Yes. Best thing, take some of the axle shims, and place them between the spacers and bell crank to take up the slop.
HiH
Ed
Thanks Ed
hey just curious on your thoughts on why tamiya had design that section to have abit of slope. my thoughts are tweak issues related maybe? to free up the steering movements? to make the steering system more forgiving under impact?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-13-2006, 05:36 AM   #692
TryHard's Avatar
TBH... The steering systems (or at least the amount of slop in them) has long been a fobbile with the TRF cars. It was worse on the old style system though... the new one is much more slop free.
It's not a mjor issue though, and doesn't seem to affect performance.
HiH
Ed
Old 10-13-2006, 07:27 AM   #693
Send a message via ICQ to rcnewb2004
Do you have a pic of where to put the shims? Sorry, my car terminology is poor and am having troubles imagining where it is
rcnewb2004 is offline   Reply With Quote
Old 10-13-2006, 07:57 AM   #694
Send a message via AIM to GuyIsDamGood
Hey TB Evo 5 Guys. . . . . I want to get a TB Evo 5; but I can`t find a Hobby Spot that has any in the U.S.
I like Shaft Drive Kits/Cars and the Evo 5 is 1 out of 2 Shaft Drive Kits that are out there(the other is the Kyosho TF-5). Shaft Drive Kits/Cars will soon be no more.
Overall; do the parts go together well? How does it run?
-I plan on putting a 10-Turn in My Evo 5(if I ever get it). Anyone running a motor faster than 19-Turns in their Evo 5? If any; please tell me the info.
Take Care.
GuyIsDamGood is offline   Reply With Quote
Old 10-14-2006, 01:18 AM   #695
cyber3d's Avatar
Why does Tamiya suggest adding a bead of glue around the edges of the carbon fibre pieces?
Anyone doin' that?
Katsu
cyber3d is offline   Reply With Quote
Old 10-14-2006, 01:27 AM   #696
cannon's Avatar
Trader Rating: 35 (100%+)
It seals the edge of the graphite to stop delaminating and also seals the battery slots against electrical shorting
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 10-14-2006, 02:56 PM   #697
cyber3d's Avatar
Very cool. Thank you. Guess I'll pick some up
Old 10-14-2006, 04:39 PM   #698
TryHard's Avatar
I don't have a pic, or camera to hand.
Basically, the shim goes on the steering post, between the steering arm (the bell crank) and the long spacer that stops the arm riding up the post. Hopefully that helps.
Old 10-14-2006, 08:39 PM   #699
oh... so u insert these shims from the end of the post where it meets the graphite board first... then the steering arms, then the shims that stop the arms from scratching the graphite board? am I correct?
Old 10-15-2006, 03:22 AM   #700
Nautilian's Avatar
Have any of you guys noticed that the bellcrank is rubbing against the bottom deck? If so any solutions? I was thinking of putting a shim between the bottom of the post and the bellcrank.
Thought?
Naut
Nautilian is offline   Reply With Quote
Old 10-15-2006, 03:23 AM   #701
Nautilian's Avatar
I think he means the following
<----- Top Deck
<----- Long spacer
<----- Shim
<----- Bellcrank
<----- Bottom of post
<----- Bottom deck
Old 10-15-2006, 04:50 AM   #702
bender's Avatar
Thought?
Naut
That's where i put my shims
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 10-15-2006, 05:35 AM   #703
Nautilian's Avatar
Bender just to confirm:
<----- Top Deck
<----- Long spacer
<----- Bellcrank
<----- Shim
<----- Bottom deck
OR
<----- Top Deck
<----- Long spacer
<----- Bellcrank
<----- Shim
<----- Bottom deck
Old 10-15-2006, 05:47 AM   #704
<----- Top Deck
<----- Long spacer
<----- Bellcrank
<----- Shim
<----- Bottom deck
OR
<----- Top Deck
<----- Long spacer
<----- Bellcrank
<----- Shim
<----- Bottom deck
<----- Top Deck
<----- Long spacer
<----- Bellcrank
<----- Shim
<----- Bottom deck
this is to cure your problem
but to cure the spacer from moving up and down from the steering post it would be like this
top deck
long spacer
shims
bellcrank
shim
bottom of post
bottom deck
hope that helps
Old 10-17-2006, 01:38 AM   #705
C van der Hagen's Avatar
White gears?
C van der Hagen is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
