Old 10-03-2006, 04:52 PM   #661
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by DDC
please explain uj??
ball end of drive shaft goes into the cup of stub axle ,which is then held together via collet/grub screw & pin
this bit needs grease on
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 10-03-2006, 09:34 PM   #662
Send a message via ICQ to rcnewb2004
Do you guys find the UJ pin slips out easily?? when I first drove it... i had to rebuild it 3 times...
rcnewb2004 is offline   Reply With Quote
Old 10-04-2006, 12:41 AM   #663
MR JOLLY's Avatar
only once on mine (but both side`s) but 7 race meetings on & no probs from the car atall
Old 10-04-2006, 03:58 AM   #664
BrainTeased's Avatar
hey putting some thread lock on the grub screw will prevent the screw from coming lose causing the pin to slide out. also if you feel that you have overtightened them next time you take them out replace the grub screw.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-04-2006, 06:34 AM   #665
Hi
Just ordered mine but what is the part number for a suitable spool for the evo 5?
Cheers
Smartypants is offline   Reply With Quote
Old 10-04-2006, 07:27 AM   #666
OleC's Avatar
Originally Posted by TryHard
Tam Blue are 14.08, Tam White 15.27.
On the chart I have, Xray white is 15.27 (rated as 17.5), Light Blue is 18.35 (rated 20), Blue 20.00 (rated 22.5), Dark Blue 23 odd (rated 25). Hence why the car feels safer on the xrays, as theres a bigger rate difference (3lb versus 1lb) between the springs.
Ed
Hi,
Would this be a chart you can share with us?
Inndoor season is starting here soon and I'll be racing with 19T on foams. Any good starting setups out there for this combo?
Cheers
Ole C
OleC is offline   Reply With Quote
Old 10-04-2006, 07:38 AM   #667
TryHard's Avatar
chart is on my website (link in sig), look under the excel documents section.
Regarding foam tyre setup... don't run them, sorry. All I can suggest is go stiff... Might want to get hold of extra centre braces too, there is one supplied with the car, but room for two more on it It's something I'm going to do myself as well.
HiH
Ed
Old 10-05-2006, 01:57 PM   #668
hi
i just came up from racing at local club and i broke TWO front uprights !!!!! i broke one, then replace it , 5 minutes later i broke another one !!!!
i did not big crashes, just litthe front crash .....
cant find a more tought replacement, alu , aloy or even plastic ... do youknow some?
DrKucho is offline   Reply With Quote
Old 10-05-2006, 03:37 PM   #669
anybody tried this?
http://www.rcmart.com/catalog/produc...ducts_id=20351
DF 03 knucles are so similar to evo 5 ones .... can anybody confirm if they would fit in a evo 5?
Old 10-07-2006, 02:16 AM   #670
RocketRacer's Avatar
i want to run 2 degrees of toe in on the rear of my Evo 5. what suspension block do i need to get to accomplish this?? thanks
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 10-07-2006, 03:20 AM   #671
im looking for harder knucles as the stock lightweigt are so breakable
i found square do aluminum c-hubs and knuckles for evo 4 , so they will fit in evo 5
theese are 20 euros at Champ (around 25 usd)
anyone use theese? should aluminum be harder on a impact? what i heard is aluminum bends , .... so the question is will it bends so easy as the stock knucle breaks?
Old 10-07-2006, 04:47 AM   #672
MR JOLLY's Avatar
1c on back
Old 10-07-2006, 04:48 AM   #673
MR JOLLY's Avatar
yes they will
evo5 carry`s over the evo 4 steering arms & castor blocks
Old 10-07-2006, 04:56 AM   #674
Remember to post what you think of the knuckles and blocks! I am waiting to hear about them.
Old 10-07-2006, 05:03 AM   #675
MR JOLLY's Avatar
one thing is
they can`t be a looser fit then kit ones
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
