Like Tree1Likes
Old 09-27-2006, 02:58 AM   #631
BrainTeased's Avatar
Originally Posted by MR JOLLY
don`t mean to be a arse with my reply
i had a evo 4 for ages done 1 bevel gear that`s it
it`s all in the shimming my man
as for my evo 5 raced at benfleet with the sarfend guy`s one block broke he`s cyclone by hitting the same corner in a chicane mine just bounced off
maybe it`s because there is a bit of play in the sus bit`s ,thus takes impact better
never had a problem ,had more things go wrong with me cyclone then this evo 5
hi jolly i was just curious have you ever had a hard crash, head-on with your evo 5? just trying to work out if the new evo 5 gears are holding up with hard impact, as i've been told with hard head-on impacts theres a chance the small pinion gear will strip.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-27-2006, 04:09 AM   #632
agp
are the car wheels of the ground ??
nope.
agp is offline   Reply With Quote
Old 09-27-2006, 05:16 AM   #633
TryHard's Avatar
Ive had a few big impacts with my evo, hard enough to move the motor and strip a spur... but I'm still on my original front Bevel and pinion. Shimmed right, there aint an issue.
HiH
Ed
Old 09-27-2006, 06:16 AM   #634
HiH
Ed
thanks tryhard
yea thats what i thought as well with correct shimming it should hold up a good as the evo 4 gears. but he insisted that he shimmed it very well and emphasised that the small pinion diff gears are the ones that get damaged during hard impacts.
only way to find out is first hand exprience my new evo 5 kit should arrive within 2 days cant wait to build it
Old 09-27-2006, 10:17 AM   #635
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
the other night i was driving like a arse all eve
battery came out 3 times ,smacked loads of other cars in the side ,in my side in to square track making
nothing atall .lucky this time maybe ,but the evo 4/5 only thing i changed was from 64dp to 48dp
shaft & 64 don`t go in my book
Edd going to try 1.5mm shims under the blocks on thurs eve, going to try it coz that other poster (dragonfire) is laughing at us
so i will get it a whirl
droop is 6 front / 5 rear now x-ray dark blue front/ blue rear 50 wt 3 hole allround
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-27-2006, 12:43 PM   #636
RocketRacer's Avatar
my first chewed bevel gear, funny thing is that i can't remember an impact that would have caused this. but anyway, i just slipped a new one in. pic is not too clear cell phone pic.
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 09-30-2006, 06:42 AM   #637
has anyone had to replace a spur yet? lol if so how long did it take? its stupid how they designed the new bulkheads without the 2 piece input shaft housing like the evo 4's
but i truely cant wait to see the lap times on this car once i finish building it that is
Old 09-30-2006, 07:42 AM   #638
quantum's Avatar
i see some people still asking about stripped bevel gears.... but isn't the one-piece bulkhead plus the floating shaft supposed to eliminate that from happening??
quantum is offline   Reply With Quote
Old 09-30-2006, 08:19 AM   #639
TryHard's Avatar
It's not too difficult, i've got it down to less than five minutes now.
Method I use is...
1) remove top deck
2) remove centre shaft (you can just squeeze it out if you remove the UJ link at the front)
3) take the pin out of the rear drive cup, and undo motor bulkhead, sliding off the rear inut shaft.
4) Loosen the lower rear bulkhead screws (allows you to remove the spur without it hitting the chassis plate)
5) Slid off the spur mount, change the spur
6) Reverse the process.
Sounds complicates, but after you've done it a few times, not really difficult.
HiH
Ed
Old 09-30-2006, 09:10 AM   #640
drew85's Avatar
hitting things on power, things move. I have not stripped one but I took a chunk out of one
drew85 is offline   Reply With Quote
Old 10-01-2006, 04:35 AM   #641
Method I use is...
1) remove top deck
HiH
Ed
thanks ed
yea i realised that last nite trying to figure out the shortest / fastest method of changing a spur.
Old 10-02-2006, 02:05 PM   #642
MR JOLLY's Avatar
Default on going setup`s
I am gone back to kit setup ,because i have completly lost the plot for this car
went on thurs eve up agaainst the big boy`s & was 1.5 sec a lap down
went to hard on springs by a long shot (x-ray dark blue )
just need blue or even just the white`s other wise the car just glide`s around with no consintencey in grip level from one corner to another
so back to basic`s
other then these bit`s
50wt front /45wt rear (oil)
x-ray blue front & x-ray white rear
even gone back to the 1D & 1XA 1E blocks , taken off the evo 4 ones
this is so embarrising owning up to this Mess
Old 10-02-2006, 09:20 PM   #643
Send a message via ICQ to rcnewb2004
Keep us posted on your setups, i cannot race for the next 8 months due to work... seeing all these different setups and the results from them makes me feel like I am still with my car
rcnewb2004 is offline   Reply With Quote
Old 10-03-2006, 02:05 AM   #644
TryHard's Avatar
Colin... you checked your tyres aren't knackered? I know your a tight wad and all
I've been running Xray Blue/ Light Blue on mine... does feel a little too stiff, especially for a flowing track. Try just the front roll bar as well, should help.
Ed
Old 10-03-2006, 02:33 AM   #645
TRF415boy's Avatar
Lolly if you drive like a whack and then complain that the car's not handling well anymore i suggest checking your hinge pins for bent ones, even slightly bent they make the car feel a real mess. To check simply turn them while in the wishbone, if you feel a hard spot it's bent and needs replacing.
TRF415boy is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
