Tamiya TB Evolution V
#601
Originally Posted by C van der Hagen
Yes, I use a modified Evo 4 spool with MRe outdrives
#602
lathed .5 mm off to have the correct position of the ring gear
#603
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
i have spool aswell ,the tamiya one for the evo 4 but with evo 5 ring gear on ,that`s it
#604
#605
Just make sure you use the evo 5 gear on it
other then that just shim it like diff or one way
#607
Less or more teeth thus different internal gear ratio for evo 5 to evo 4
won`t mesh properly ,so don`t bother trying
#609
if i remember right... its 2.375
#610
Front
Droop 25mm (top of axle,with wheels off,sitting on flat surface)
one-way
silver rollbar(kit one)
outer hole on tower(shock)
outer hole on w/bone
white springs.3 hole.45wt
3mm spacer inner camber link
1Efr,1Drr,1mm spacers under blocks or Efr;Drr std evo 4 blocks ;no shims
1st hole on steering hub
4 degree castor blocks
Rear
Droop 24mm
no rollbar
hole 2 /tower (shocks)
outer hole w/bone
blue springs/3 hole/45wt
.5mm inner camber link
.5mm outer camber link
position B on hub(i`m going to make longer & use C hole next time)
1 Xfr;1Drr (1mm shims under blocks)or Xfr;Drr if using evo 4 blocks /no shims
Memo
rear links to be made longer
use 55wt oil up front
reconnect rear roll bar (kit one)
i see it as using soft springs i can make use of roll bars to help in corners !!
48dp 72
wheel base is as Kit front & back
camber link holes on bulkhead is Kit
shock length`s 62mm
one-way
Rear
Droop 24mm
no rollbar
outer hole w/bone
Memo
48dp 72
shock length`s 62mm
front
x-ray 25ilb
second hole in on tower
rear
disconnected rollbar
x-ray 25ilb
hole `C` on Hub (made longer) like this
took .5mm shim out on Hub aswell
car could easily stay with the TQ boy`s at the club ,one of them just set new track record down Barham with BD, asphalt), the other races with Dave spashett cos he is dave`s pit man @ worlds & wot not ,so he can drive fast aswell (well underated this guy)
Memo
tamiya springs are to soft even the white`s, blue`s are equal to x-ray white`s (17ilb`s), so dark blue front25ilb(blue rear 22ilb will be a good thing by far
just carry`s so much more speed through sweepers/chicanes running the x-ray springs (indoors only this for rubbers/carpet jack the gripper additive
#611
race this friday (only made D final more to do with health then car) so don`t worry
front
x-ray 25ilb
rear
x-ray 25ilb
Memo
front
x-ray 25ilb
rear
x-ray 25ilb
Memo
#612
Originally Posted by stuey
i got that wrong colin tamiya blue are 14lb tamiya white are 17.25lb
antway x-ray 25-22.5 are so much better
think tamiya should bring out some carpet springs ,more progressive one`s at that aswell
#613
Any of you Tamiya guys running the V modified
Lots of belt guys running their yaps about belts. Any of you running your new V's modified??? I am running the car that is like yours (the V is on steroids compared to the Pro4) with the 4.5 and envy all that aluminum Tamiya provides you with. Throw me a friggin bone here.
#614
Can one of you guys try out gearing on one of these...
I want to know what the smallest ratio you can fit in it is. I am not worried about a little filing to the spur gears slots on the upper lower decks to fit bigger gears, or it sticking out the bottom as I always run 6mm ride heights anyway. I want to see if you can get about 20mm rollout on rubbers (10:1 FDR)
cheers
cheers
#615
cheers
cheers
