Old 09-20-2006, 03:06 PM   #586
m3ndo5a's Avatar
Originally Posted by RocketRacer
will my roll centre increase or decrease? how will it affect the cars handling??
Increase/Less grip (Higher Roll from the inner Lower arm)
Counter by increasing the inner Camber link or lower the outter Link.
m3ndo5a is offline   Reply With Quote
Old 09-20-2006, 03:24 PM   #587
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default Blocks
evo 4 came with it`s own evo 4 blocks , now the evo 5 come`s with the MSX range of blocks with 1 before each letter ie;;1D.1E,1X etc
evo 4 just had D.X,A,C
the 1D say`s 1mm lower then D block
i had all the evo 4 blocks here & not enough 1+ letter blocks
all you do is add a 1mm shim beneath the 1mm+letter blocks to be the same as the evo 4 blocks (i was penny pinching to save money)
raise blocks raises Roll centre ,basically makes car respond quicker to driving input`s like having less droop,keeps car flatter in turns
down side it does take grip away
just works realy well for me
Dotman has asked for setup of my car
i`ll be back with it ltr
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-20-2006, 03:32 PM   #588
MR JOLLY's Avatar
@ Mr Jolly, what rollout do you run with the 27T motor? what pionion and spur combo?
can i run the Evo 4 suspension blocks on the Evo 5?
i had a 72 spur/22 pinion 8.06 for a tight 11 sec lap 23 laps in total
Old 09-20-2006, 03:49 PM   #589
MR JOLLY's Avatar
Default Setup evo 5 rubbers/co27t/v-tech 24r
Front
Droop 25mm (top of axle,with wheels off,sitting on flat surface)
one-way
silver rollbar(kit one)
outer hole on tower(shock)
outer hole on w/bone
white springs.3 hole.45wt
3mm spacer inner camber link
1Efr,1Drr,1mm spacers under blocks or Efr;Drr std evo 4 blocks ;no shims
1st hole on steering hub
4 degree castor blocks
Rear
Droop 24mm
no rollbar
hole 2 /tower (shocks)
outer hole w/bone
blue springs/3 hole/45wt
.5mm inner camber link
.5mm outer camber link
position B on hub(i`m going to make longer & use C hole next time)
1 Xfr;1Drr (1mm shims under blocks)or Xfr;Drr if using evo 4 blocks /no shims
Memo
rear links to be made longer
use 55wt oil up front
reconnect rear roll bar (kit one)
i see it as using soft springs i can make use of roll bars to help in corners !!
48dp 72
wheel base is as Kit front & back
camber link holes on bulkhead is Kit
shock length`s 62mm
Old 09-20-2006, 04:05 PM   #590
Thanks, Mr J.
DOTMAN is offline   Reply With Quote
Old 09-20-2006, 04:15 PM   #591
Hey, Mr Jolly - what oil do you use? (AE, LOSI?)
Old 09-20-2006, 04:20 PM   #592
stuey's Avatar
[QUOTE=MR
not nesasrely colin you get less roll with a higher block you don't always get less grip tho you will find the car tends to use the tyres more rather than the roll of the car prime example if you have grip roll you can lower the blocks to make the chassis roll through the corners more hense removing a little side bite from the tyres.
stuey is offline   Reply With Quote
Old 09-20-2006, 08:55 PM   #593
agp
hi guys, not sure if this is a common issue with evo 5 chassis. When i press throttle and turn my steering to the right, i found out that the front left and right tyre start to vibrate and make some sound. when turn steering to the left, the is some vibration but minimal.
I have just change my front way unit to ball diff. any advise guys?
fyi, i have place 1x0.3m shin on left and 1x0.3m+1x0.1m shin on right.
agp is offline   Reply With Quote
Old 09-20-2006, 10:43 PM   #594
drew85's Avatar
chatter from the cvds cut them out or turn down your steering. and set your epa's while your there.
drew85 is offline   Reply With Quote
Old 09-21-2006, 12:01 AM   #595
agp
sry.. dun quite understand.. can explain more?
Old 09-21-2006, 12:08 AM   #596
RocketRacer's Avatar
i nee some advice please
Tyre diameter = 60mm ( foam tyres)
tight asphalt outdoor track longest straight is about 50feet.
Team Orion Core stock motor.
i currently have the 96t Spur in the car.
where would be a good place to start for the gear ratio and rollout?
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 09-21-2006, 12:47 AM   #597
MR JOLLY's Avatar
AE oil
keep all the same make if poss (they vary alot)
Old 09-21-2006, 12:55 AM   #598
MR JOLLY's Avatar
i`m racing at a more competitive club on friday night with this setup,
so i will be back (i only make the B`s there) was quite often at the top or in top 3 with my evo 4
but evo5 prior before setup was well of pace
i did try the front ackerman hole on hub ,man that made it steer ,put it back to std for now
Old 09-21-2006, 07:10 AM   #599
Holmenkollen's Avatar
Anyone have a spool for Evo V?
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 09-21-2006, 07:37 AM   #600
C van der Hagen's Avatar
Yes, I use a modified Evo 4 spool with MRe outdrives
C van der Hagen is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
