Old 09-15-2006, 01:56 PM   #571
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by Hebiki
i think he might be asking about the actual length of the shock. between 59-61mm is a good length to start with.
i have 61.5mm
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-15-2006, 08:35 PM   #572
Send a message via ICQ to rcnewb2004
Oops sorry.... i didn't think he was refering to shock length. btw, hebiki, did you get the cap you wanted?
rcnewb2004 is offline   Reply With Quote
Old 09-16-2006, 12:33 AM   #573
TryHard's Avatar
Originally Posted by Rep1v
I also own a Evo V, is just love the looks of de car and I hope that it will drive just as good as it looks. I just have a little question: How long do I have to make the shocks?
Long enough so you can use the amount of droop you want to run. Personally, I have mine set at 62.5mm.... lets me use down to 3 on a yokomo gauge for droop.
HiH
Ed
Old 09-17-2006, 07:28 AM   #574
BrainTeased's Avatar
hey guys!
im just curious with guys that have both the 415 and evo 5 chassis, have any of you guys done a back to back comparison run with the 2 chassis and find one chassis faster than the other in terms of lap times?
also im looking for responses from stock 27T / 23T and 19T drivers
thanks!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-17-2006, 01:47 PM   #575
MR JOLLY's Avatar
Edd
can i use the evo 4 blocks ?? so then i don`t have to run shims under the newer MSX blocks
i have gone for -5 degree toe out on front & 2.5 degree rear toe In
my evo 4 was very much faster then the evo5 kit setup ,the biggest difference between the 2 was the roll centre`s
the newer blocks are all 1 mm lower then the std evo4 blocks
Old 09-17-2006, 03:10 PM   #576
TryHard's Avatar
No reason why not. For maritme (and tight tracks in general) I found high roll centres worked well. With 2.5 deg, you could use E and X for the rear blocks, no worries.
HiH
Ed
Old 09-19-2006, 12:40 AM   #577
agp
confirmed parts need to build a ball diff. thx for those who help out. Just got my parts from Tamiya distributor today.
1. Diff Joint #9808068
2. Ball diff gear #51256
3. Swing shaft protector #53890
4. 3mm lightweight diff ball set #53379 (20pcs perpack, need oni 10)
5. TA04 ball diff plate #50880
6. 850 sealed bearing set #53030 (4pcs perpack, need oni 2)
7. 620 Thrust bearing #4950344493005 (2pcs per pack, need oni 1)
8. Ball diff spring #4950344492992 (2pcs perpack, need oni 1)
9. 2x25mm capscrew with nut #4950344493500 (2pcs perpack, need oni 1)
any1 live in sg wanna built ball diff, we can share item 4,6,7,8 and 9. we the cost half half. just pm me.
agp is offline   Reply With Quote
Old 09-20-2006, 07:44 AM   #578
MR JOLLY's Avatar
Edd car is flying now
raced against Foam racers with rubber on mine 5 th in the A then won the final ,
putting the evo 4 blocks on or raising the std ones with 1mm shims is very good ,every thing is tamiya no x-ray springs & all white front ,blue rear roll bars back & front ,i do my droop by measuring from the top of stub axle to the pitboard 25mm front,24mm rear
i gave -5 dgree toe out on front E front-D rear;,that made it really lively upfront ,kept them on & worked around that,will legthen the rear camber link to go in outside hole (C) on hub
45wt all round,3 hole ,toying with idea of going 2 hole
got X front/D rear on the back blocks 2.5 toe in (i think),confusing them blocks
looking at the MRE,MSX setups on certain indoor tracks rubber/carpet they put .5 to 1mm shims under blocks also
this diffiently is a good thing to do for indoor racing ,cyclone do it ,BD yoke on front
using a 72 spur br robinsonracing with 22 pin ,well fast with co27t/F-lines from EA
Old 09-20-2006, 10:29 AM   #579
RocketRacer's Avatar
@ Mr Jolly, what rollout do you run with the 27T motor? what pionion and spur combo?
can i run the Evo 4 suspension blocks on the Evo 5?
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 09-20-2006, 12:31 PM   #580
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes you can.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-20-2006, 12:32 PM   #581
Hebiki's Avatar
yessir... used it a couple of weeks ago at the Ko Propo Grand Prix... WEEEEEEEEEE!!! that thing is dialed
Hebiki Design Works
Old 09-20-2006, 12:41 PM   #582
yes you can.
would i need to run spacers or anything? how does the height of difference affect the chassis?
RocketRacer
Old 09-20-2006, 01:49 PM   #583
Hebiki's Avatar
evoIV blocks sit 1mm higher than evoV/415 blocks. since they are 1mm higher, your roll center will change.
Hebiki Design Works
Old 09-20-2006, 01:56 PM   #584
TheCoolCanFanMan's Avatar
Hi Guy's
As the doctor ordered well you racers anyway
I have now designed a CCF + which is a separate carbon fibre bracket that can be attached to your existing CCF, The fan can sit above or below the carbon fibre bracket and can be cut to the desired length when the desired position has been adopted. It will hang over the speedo to help keep it from over heating, this item is especially useful for the brushless speedo’s because of there thermal cut out. There will be different length screws along with different length carbon fibre stand-off collars. all for £19.99 of your Britsh pounds and will fit onto ALL CCF's except JRX-S
Cheer Malc THE CAN MAN
The car in the photo is Chris Kerswells, and its the first of its type.
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 09-20-2006, 02:30 PM   #585
will my roll centre increase or decrease? how will it affect the cars handling??
RocketRacer
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
