Old 07-28-2006, 02:22 PM   #466
stuey's Avatar
hey edd (try hard)
you got pm.
stuey is offline   Reply With Quote
Old 07-28-2006, 03:17 PM   #467
stuey's Avatar
can any body post the base setup for evo 5 as per manual
Old 07-29-2006, 04:27 AM   #468
KORSA's Avatar
The bigger spur is 100T with the smallest pinion 23T and inside ratio 2,4375 final 10,5978 ratio. This for low brushless guys.
KORSA is offline   Reply With Quote
Old 07-29-2006, 04:43 AM   #469
are you sure KORSA? you mean with no mods?
which diametric pitch are you using
DrKucho is offline   Reply With Quote
Old 07-30-2006, 07:41 AM   #470
TryHard's Avatar
Sounds like 64dp to me...
Anyway, just came back from my first meeting with the Evo5... pretty awesome to say the least.
Started the day basically as kit, bar a couple of exceptions. Didn't run the roll bars, and used Tamiya white on the front, and blue on the rear. Also ran X/E on the rear (2.5deg toe in) Kept the 1-ways in as I was running on carpet (hence the setup changes).
Wow.... car has so much steering, I had to adjust the expo a fair bit on the transmitter to calm it down, and adjust my driving.
Made one change to the car during the day, and that was to move the rear camber link to the outer hole on the hub. This worked a treat, and made the rear of the car transition much better, ment I could lean on the car more into the turns.
Ended up TQing each round, and won the first final.... unfortuantly got clipped a pipe in the second and stripped the spur...
Still was comfortably the fastest car there, most of my final lap times were sub 10sec, and everyone else was above 10...
I think this car is going to be perfect for what I have in mind for it (indoor stock racing)... If the MRE MSX handles like this, gonna be awesome
TryHard is online now   Reply With Quote
Old 07-30-2006, 11:04 AM   #471
stuey's Avatar
hey edd
cheers for the basics what about wheel spacers top camber link washers akerman posions etc
stu r
Old 07-30-2006, 12:27 PM   #472
TryHard's Avatar
Stu,
Wheel hexes, 5mm width, 0.5mm spacers.
Camber links, out hole on bulkhead F/R, 3mm under front link, 2mm under rear.
1.5mm under rear hub ball joint (middle hole)
ackerman position, no spacers on steering bridge, rear hole on steering hub.
One thing to note.... the steering horn setup is a little different. Basically, Looking at the servo from the front, mount the ball joint in the middle hole, but zero it up on the left hole (as on the diagram). You also need to chop off the right hand section of the horn.
HiH
Ed
Old 07-30-2006, 03:15 PM   #473
still need to know if that is with no mods...
Old 07-30-2006, 04:34 PM   #474
TryHard's Avatar
I have a 100tooth in my car now, and it just clears the top deck.... can't quote for the pinion (i don't have a 23t), but my 25 fits fine.
HiH
Ed
Old 07-30-2006, 04:39 PM   #475
HiH
Ed
thank you tryhard! that helps a lot
now , my money is burning in my pocket !!
Old 07-30-2006, 05:24 PM   #476
Send a message via ICQ to rcnewb2004
What would be a good ratio to run for a 10T on the tb V?
my lowest right now is a 6.88.... do u guys think i may burn something?
rcnewb2004 is offline   Reply With Quote
Old 07-30-2006, 06:18 PM   #477
stuey's Avatar
cheers edd
Old 07-31-2006, 05:49 AM   #478
KORSA's Avatar
Yes my friend, without any modification you can use 100T spur with 23T pinion 64 pitch. The only problem is that you can't use the aluminum heat-sink for the motor, because there is no space from the upper deck to the motor.
Old 07-31-2006, 05:56 AM   #479
thank you sir !!!
motor heat sink is no problem , it can be dremeled
Old 07-31-2006, 01:28 PM   #480
Blueman Austria's Avatar
Hi all !
I have a question. Does the Damper Stays from the evo 5 fit also the evo 4 ?
The gap between the holes is lokking very similar then the evo 4 ones.
Greetings form Austria
Blueman Austria is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
