Like Tree1Likes
Old 07-17-2006, 02:14 AM   #451
Originally Posted by TRF415boy
OMG Colin I SOOOO can't believe you just said that ! The only way to have 0 Castor is to use 0 C-Hubs...
You will have zero caster if you run standard c-hubs with 4 degrees kick down on the front. But your car will also push off power!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-17-2006, 03:34 AM   #452
bender's Avatar
Ran my Evo5 for the second time at my local track yesterday
Due to the inconsistant track conditions (had some intermittent rain periods) I didn't really get to try to many different things, but I stll managed to go quicker.
My best race time was 1 second off my personal best with the MSX, and I did a fastest lap that was only 0.14 seconds off my best
So, it's taken me approx 2 meetings to get this car as quick as MSX, which took 4 months to reach these lap times
For stock or 19T this car is bloody quick
One thing I noticed, I can run a higher rollout with this car when compared to the MSX. I ran about 2mm higher rollout yesterday, still had more punch than what I ever had with the MSX, and the car was THE fastest thing in a straight line!
Did I mention I really like this car
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-17-2006, 02:55 PM   #453
JimmyMac's Avatar
Xenon sells 0degree castor blocks. I have some. But haven't tried them yet...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-17-2006, 04:42 PM   #454
veecee's Avatar
Trader Rating: 34 (100%+)
Good to hear your positive reports on the car. I'm really looking forward to give mine a run. In fact I was hoping to try my car tonight but Sydney weather is not on my side... Just curious about how you're shimming the gearboxes. I've heard a lot of conflicting views with some people finding the factory recommendation inadequate. How have you shimmed your gearboxes?
veecee is offline   Reply With Quote
Old 07-17-2006, 11:24 PM   #455
bender's Avatar
I shimmed it as per the manual (which felt a bit off), ran it in a bit (at low volts) and then pulled the whole thing apart again and re-shimmed it.
Most likely, everyones settings will be slightly different, but with the car shimmed as per the manual, I found that my car had too much end-float in the input shafts.
Jason W
Old 07-17-2006, 11:27 PM   #456
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Shimming is always something worth taking your time with too, especially with a shaft car. You will notice the difference heaps - I know I did with my Evo4 when I had it.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 07-18-2006, 01:20 AM   #457
Send a message via ICQ to rcnewb2004
Hey bender, how did u re-shim it?
I just finished building my tb evo 5.... going to be done tuning it soon and get it on the road for its maiden run.... hehehe
so happy right now.... so excited... hehe
rcnewb2004 is offline   Reply With Quote
Old 07-18-2006, 04:10 AM   #458
C van der Hagen's Avatar
My experience is that the manual settings regarding the shims are prefect. I race my Evo 5 for a month now (with a 7x1 turn motor) and didn't have any problem with it.
Only dislike on the car is the gearbox covers. They don't fully seal the gearbox, sand and dust is getting in. The Evo 4 covers are much better but don't fit the Evo 5
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 07-18-2006, 05:59 AM   #459
@C van der Hagen
Did you drive the evo V at the NK modified class? Or haven't you used it in the competition yet.
If so, how did it drive on the HFCC track?
Alwin.
F1mechanic is offline   Reply With Quote
Old 07-20-2006, 04:53 PM   #460
7x1 turn motor !!! how about the torque steer? do you notice it running such powerfull motor?
also which ratio are you using?
DrKucho is offline   Reply With Quote
Old 07-20-2006, 09:43 PM   #461
I noticed no torque steer.
I raced 1/8 gas track (baanbrekers, rucphen)
Gear ratio was 100/33
I didn't race the NK race @ HFCC, because of rain. Maybe i'll use the evo 5 this weekend @ AMCA.
Old 07-21-2006, 07:12 PM   #462
what's that? 100T spur + 33T pinnion? so 7,38 final ratio?
i am trying to know the lowest gear ratio you can get on a evo 5 with no mods, so what do you think is the bigger sput gear you can put on a evo 5? 100T? also which diametric pitch are you using?
for me will be easy to dremel the upper deck in order to host a bigger spur, but the problem will be the spur showing up under the lower deck so it will be damaged by the ground ... if anyone can take pictures of the 96T (or bettter other big spur) showing how close is it to the low deck top ... that will help a lot
i dont want to spend my money in a evo 5 before knowing if i will be able to run my novak 5.5 which needs final ratios from 8 to 10
thanks in advance
Old 07-21-2006, 07:18 PM   #463
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
You can get around 8.6 ratios, definitely a 9 is out of the question without mods.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-22-2006, 03:14 AM   #464
yes im sure i will need to mod it but i want to know what is the limit with no mods so i can have an aproximate idea of how much the mods will be
8.6 sounds not bad
anyone with pics of the spur from the down of the car?
Old 07-24-2006, 11:06 AM   #465
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default flex
quick questions for the carpet guys
how is the flex on the EVO 5? Does anything need modding to make it carpet ready.
thanks for any info
olhipster1 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
