Like Tree1Likes
Old 07-12-2006, 08:08 AM   #436
Just putting my EVO V together at long last , seems to be a good step up in terms of quaility over my old EVO III. I just hope it goes as fast as it looks.
Just need to sort of few items out like some 64dp spurs , motor , new tyres etc and i will be all ready to race.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 07-12-2006, 08:20 AM   #437
Hi Guys, I'm thinking to get a EVO5. But i've got a question first.
How "easy" is it to change a spur? What are the steps?
remove top deck, remove motor mount, slide out spur adaptor?
Any idea?
Kasey is offline   Reply With Quote
Old 07-12-2006, 10:31 AM   #438
Any idea?
Its not that easy really:
Remove top deck, rear gearbox, motor mount, centre prop shaft cup then the spur gear mount then you can remove the spur.
Rick Draper is offline   Reply With Quote
Old 07-12-2006, 11:12 AM   #439
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default evo 5
spur gear change...
I have found in shafties...if you take the top deck off and just the unscrew the motor mount then slide it off....it spur gear should be exposed to allow the removal...assuming the lower chassis spur gear opening allows for a little movement forward...Can this be done in an Evo 5??? which way do the spur gear screws face?
I'm dying to get an EVO 5....post up some pics .....come on guys...Need to see how everyone is placing electronics.
olhipster1 is offline   Reply With Quote
Old 07-12-2006, 11:41 AM   #440
I ran my EVO for the first time this past Sunday and it was great. The steering was incrediably responsive but at the same time very stable. The car wasn't twitchy at all. The funny thing about that is I found after the first run that I had my castor blocks reversed. I actually had 4 degrees of positive castor on each side. The car was awesome like that. I had no motor and I was still able to run with the faster guys. It was so good, I'm debating whether I want to switch the blocks back
DOTMAN is offline   Reply With Quote
Old 07-12-2006, 02:17 PM   #441
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Pic`s
42`s are really close to the rear input drive cup aswell (but doesn`t touch)
also car needs 80g of weight added to bring upto scratch (only got on 40g at the mo)
Tamiya TB Evolution V-renate-thankyou-008.jpg   Tamiya TB Evolution V-renate-thankyou-010.jpg   Tamiya TB Evolution V-renate-thankyou-009.jpg   Tamiya TB Evolution V-renate-thankyou-011.jpg   Tamiya TB Evolution V-renate-thankyou-012.jpg
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-12-2006, 02:19 PM   #442
MR JOLLY's Avatar
i`ll get pics with Paek Li-Po in next time i`m dossing about
Old 07-12-2006, 02:20 PM   #443
Hebiki's Avatar
Trader Rating: 26 (100%+)
i might have to try that. i added 2mm spacers on the steering rack. got more steering more experimenting this sat.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-12-2006, 03:50 PM   #444
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally Posted by TryHard
the biggest problem I have is that the spur is very close to protruding below the chassis. I reckon a 100tooth is about the limit in that regard, before the spur stick out below the chassis.
HiH
Ed
In 48 pitch terms, 73 tooth will be just level below the chassis. Looks like the car wasn't made for top end modified racing in mind.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-12-2006, 03:53 PM   #445
TryHard's Avatar
Originally Posted by MR JOLLY
Pic`s
Hey colin,
your steering link is in the wrong place... on the servo horn the nut should still be in the middle hole, and you line it up on the outer one... take a close look at the destructions
| THard.co.uk | Xray | MuchMore |
Old 07-12-2006, 11:20 PM   #446
MR JOLLY's Avatar
Oh is that what instructions are for ,
i build it then when it goes wrong then look at the destructions
might actually use it this thurs down maritime , just to see how it goes
if you reverse the 4 degree castor blocks , then you have zero yes/no
or would you have 4 degree anti-dive
Old 07-13-2006, 07:47 AM   #447
What are the part numbers for the A , B , C and X suspension blocks for the EVO V as im about to send an email of to champ for a whole bundle of bits. Getting bevels gears , suspension blocks , ball diff parts so anything else worth getting while im at it ???
Old 07-13-2006, 09:09 AM   #448
Assuming your suspension blocks are even on both sides, you would have 4 degrees positive castor (anti-dive)
Old 07-16-2006, 07:06 AM   #449
Positive caster and anit dive are 2 different things.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-16-2006, 10:12 AM   #450
TRF415boy's Avatar
OMG Colin I SOOOO can't believe you just said that ! The only way to have 0 Castor is to use 0 C-Hubs...
TRF415boy is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
