Like Tree1Likes
Old 07-09-2006, 04:54 AM   #421
hey guys...
Considering going back to a tamiya ride and looking at the evo 5. What do you get in the kit? Which toe blocks? Springs? Sway bars?
Also, where is a good place to get one from?
What spares are recommended... I have heaps of spares for my 415's so only the different parts...
Thanx...
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-09-2006, 05:49 AM   #422
RMF-888's Avatar
Send a message via Yahoo to RMF-888
Post
guys wat do you think is the advantage of the EVO5 to the TRF415MSX?
[ MUGEN ] [ WERKS B2 ] [BITTYDESIGN] [ AKA ] [ BYRON FUEL ] [ SANWA ]
[ HOTBODIES ] [ FUTABA ] [ TEKIN ] [ HARA TWISTER ] [ SPEED PASSION ]
CENTRAL LUZON RADIO CONTROL CLUB
RMF-888 is offline   Reply With Quote
Old 07-09-2006, 07:25 AM   #423
TryHard's Avatar
Originally Posted by MR JOLLY
just drill hole or ream it so you can put hex drive straight in to undo & adjust
Found a better method now, just chop the top off, like for the rear sway bar ball cups... make a much cleaner hole.
I've now sorted my car (had the steering bell crank ball joint in the wrong place... opps), and it's all setup properly... which maybe a bit premature given I won't be able to run the car for a while :'(
TryHard is online now   Reply With Quote
Old 07-09-2006, 12:04 PM   #424
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
when i used your setup block sheet
with 1xa - 1 e it comes out 5 drgree toe in on the table
i want 1 degree toe out front
shall i put x on ??
to many shim`s on this car bloody loads
spur gear is even harder to change then evo 4 (if you had the 2 piece motor mount that is )
nearly all built with nitride sus pins & nitride shock shaft`s
blue & Ti screw set on
thing that i noticed ,that might help stop bevel pinions stripping ,put more shims on the input shafts to push bevel pinion deeper into the gearbox to have better face contact with bevel gear, you can then shovety the diff side to side to get the play with out binding
since the diff setup uses 0.03mm shims either side you have a lot to play with
when i dine it per manual (my perssonal feeling) was the bevel pinion is to far away from the gear
hope this helps
only stripped 1 gear on my evo 4 running indoors @ break neck speed
i have had SD from the start & eneded up with a lcg , so shaft & me are like husband & wife
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-09-2006, 02:52 PM   #425
TryHard's Avatar
shall i put x on ??
hope this helps
woudl help if you looked at the zero degree hub chart rather than the 2deg one.... hence why you get 5deg
For 2.5, X/E is what you want
1 deg on the front... D/B
I'll have a look at the pinion gear shimming, got plenty of time before I run it... ta
Old 07-09-2006, 06:40 PM   #426
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Dragonfire
hey guys...
Thanx...
toe blocks: D, D XA, E
Springs: four yellow springs
sway bars: silver. but looks to be the same diameter as tamiya yellow or blue sway bars. someone with calipers can measure and confirm.
recommended spares: one of each? caster block, steering knuckles, a set of arms. (arms comes with one rear and one front).
also get those flange tubes that go underneath the steering and is held in by a 3x8 button head screw.
good luck!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-09-2006, 11:35 PM   #427
MR JOLLY's Avatar
good luck!
on my car they are held in place with a counter sunk 3x8 screw
, but if you lose these then tobee craft do some nice blue shouldered 1 piece screw that get`s rid of the flange tubes
Edd
i`l try harder to look properly
Old 07-10-2006, 08:49 AM   #428
TryHard's Avatar
Done, about 0.2mm thinner than the yellow ones... so my guess is that they are equivilent to the yellow minus paint
Old 07-11-2006, 12:31 PM   #429
MR JOLLY's Avatar
built the evo 5 , then took the front input shaft out again & redone the shimming
if you shim it like the manual say`s , then the input shaft moves about to much , if you turn 1 wheel on front you can see the shaft moving up & down
manual has it 4(6) xME1 shims bevel gear side & 5(8)x ME2 shims on centre cup side , in brackets i have put this on mine
shaft is much more sound & doesn`t move around alot (binding isn`t noticeble either)
you might use 1 less either side or you might not
HTH
the rear is no prob`s, (not keen on circlips on bevel either )
Old 07-11-2006, 07:05 PM   #430
So the evo5 comes with only 1 stabiliser at both ends, one toe setting both ends. are the stabilisers the same as the 415's? What is the toe setting? Does it come with the 0 degree rear hubs(alloy)?
Can someone confirm that u can achive a rollout of about 20mm with rubbers? thats an fdr of about 10:1
thanx...
Powered by Falco
Old 07-11-2006, 08:37 PM   #431
veecee's Avatar
Trader Rating: 34 (100%+)
thanx...
Yes only 1 med stabiliser at both ends (bare silver, non-powdercoated). Part # for a full set is 49392 - TB Evo V Stabilizer rod set. This includes 3 pairs.
There are no extra toe blocks - only 2x Ds, 1x XA, 1x E. The 2x Ds are used on the front which gives the rear end 3 degs with the other blocks. In theory you could run a bit of inboard toe at the front (E and D) and run 2.5 degs rear toe (XA and D). And that's with the supplied 0 deg alloy rear hubs.
I'm not sure if you'll get 20mm rollout. I just finished building mine last night for stock with 72T spur and 29T pinion (48 pitch). That combo gives a 33.75 rollout and there's not a lot of clearance for that spur. I wouldn't think you could go much bigger than a 75T spur before reaching for dremel. With that spur and pinion combo, the motor was mounted 1/3 of the way from the end of the mounting slots (relative to the centre of the car).
veecee is offline   Reply With Quote
Old 07-11-2006, 10:24 PM   #432
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Maximum allowable spur is 72-73 tooth (48 pitch) and a 20 mm rollout is not achievable by the looks of it.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-12-2006, 12:01 AM   #433
bender's Avatar
21/73 is the smallest ration I've managed to fit on the car - and that's a FDR of 8.47:1
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-12-2006, 06:46 AM   #434
From what I remember, the upper deck is narrow on both sides of the spur meaning you can't dremel much. Is there clearance at the bottom for a bigger spur? If there is, you could easily "camber" the edges of the upper deck next to the spur which would allow a few more teeth. The smallest rollout I have run recently is 23mm which would be about 8.7:1. So mayb there is no probs with a bit of work but would rather know before I buy considering it is normal for me to get two kits at once.
I assume RC-Champ is still the best source of all things tamiya?
Powered by Falco
Old 07-12-2006, 08:03 AM   #435
TryHard's Avatar
I've got a 98t (64dp) spur in my car at the moment, there is plenty of side to side clearance on the lower chassis, and enough on the top too (although I have cambered the top deck just in case). the biggest problem I have is that the spur is very close to protruding below the chassis. I reckon a 100tooth is about the limit in that regard, before the spur stick out below the chassis.
HiH
Ed
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
