Old 06-14-2006, 07:12 AM   #301
Originally Posted by Hebiki
Ed.. COOL! can you cut me a TRF415MSX chassis and upper deck that accomodates the steering assembly from the EvoV
ill have an editable EvoV set up sheet soon. i have a 415MSX one if you want it for your site.
I am currently about to order a Evo v and a evo V steering setup from champ. Then the evo chassis will be been sent off along with a 415 chassis and top deck to be measured and cut for the new steering setup.
Rick Draper is offline   Reply With Quote
Old 06-14-2006, 08:58 AM   #302
Hebiki's Avatar
Trader Rating: 26 (100%+)
rick.. keep me posted on that. id love to throw on the EvoV steering onto the MSX.
tryHard.. did you hear that?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-14-2006, 12:56 PM   #303
Joel Lagace's Avatar
How do 28mm foams fit on the front and rear of the car? Any rubbing or modding needed?
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-14-2006, 03:00 PM   #304
C van der Hagen's Avatar
Finished my car. But the Evo 4 spool doesn't fit. Is there an aftermarket spool available?
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 06-14-2006, 04:52 PM   #305
Trader Rating: 24 (100%+)
Does anybody have the TAMIYA part numbers for the steering parts? The aluminum plate and the swing arms from the EVO V? Thanks~
JoeyE is offline   Reply With Quote
Old 06-14-2006, 09:00 PM   #306
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hey Hebiki what is the internal ratio for the EVO 5? will the EVO 4 bevel gear fit the EVO 5?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-14-2006, 09:13 PM   #307
Trader Rating: 17 (100%+)
not sure? almost everything is included the kit already. only thing you can buy are the following:
- aluminum servo mounts
- Ti/aluminum screws
- Ti coated suspension hinge pins
- Ti coated shock shafts
- aluminum shock spring retainers
these hopups (minus the screws) dont add up to much. maybe $30-$40?
hi hebiki, what are part number for aluminum servo mounts, Ti coated suspension hinge pins and aluminum shock spring retainers. thanks
EngTat
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 06-14-2006, 10:10 PM   #308
Leester's Avatar
Trader Rating: 20 (95%+)
Originally Posted by Leester
Hello
When can i buy the evo V lower steering linkage. and when can i buy the Evo V arms? for my 415MSX
-Lee
Anybody?
Leester is offline   Reply With Quote
Old 06-15-2006, 12:45 AM   #309
Hebiki's Avatar
Steering bridge: 3455974
Steering arm (x2): 9808066
Steering post (x2): 9808065
Steering Spacer: 9808067
internal ratio is: 2.437
EngTat
alum. servo mounts: 53723
shock retainers: 49311
Ti coated suspension hinge pins: 53851
please send donations to my paypal account hebiki@gmail.com for all my hard work!
Hebiki Design Works
Old 06-15-2006, 12:47 AM   #310
Tamiya 53928 Short reversible Suspension Arm is now in stock now at RC Champ.
Please email to champ_international@yahoo.co.jp if you are interested.
Fujio is offline   Reply With Quote
Old 06-15-2006, 12:52 AM   #311
Hebiki's Avatar
man its your lucky day! i have some 28mm foams that came with a car i purchased (T2)... the front does NOT it. you need 6mm hexes. the car comes with 5mm. it hits the steering knuckle.
for the rear: using the kit setup.. the foams hit the bottom part of the shocks. so either mount the shocks on the inner hole (from the kit set up) or again.. use 6mm hexes.
my next trick.. i will read your mind.......
you want to know the part number for 6mm hexes... right?
they are: 53569
again.. paypal donations are accepted for all my hard work.
Hebiki Design Works
Old 06-15-2006, 12:53 AM   #312
Hebiki's Avatar
Anybody?
lee... email your LHS..and ask them for the availability.
Hebiki Design Works
Old 06-15-2006, 01:20 AM   #313
Default Super stock pinion
Hi
what pinion do you use with the evo 5 for a tamiya super stock motor
thanks
junn is offline   Reply With Quote
Old 06-15-2006, 01:30 AM   #314
thanks hebiki
Tamiya TB Evo 5
Old 06-15-2006, 07:37 AM   #315
yyhayyim's Avatar
Talking Tamiya EVO 5 Better than PRO 4 Hara & Yokomo LCG?
I have read and been told that the new Tamiya EVO is actually is a better/improved kit over the PRO 4 Hara edition and the Yokomo MR4TC SD LCG...supposedly it have an even lower CG, top deck, shaft, drivetrain, etc, than the already super low Yokomo LCG. Is this true? Can anyone really confirm this? Can anyone come up with concrete evidence- where are the numbers? Its just hard to believe they have figured out a way to make the car with more lower CG and shaft/drivetrain than the Yokomo LCG- that is amazing....if its true- Please let us have the data that would confirm this, and if indeed its true, then I will be buying the awesome kit....
yyhayyim is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
