Like Tree1Likes
Old 06-10-2006, 08:03 PM   #256
Send a message via ICQ to rcnewb2004
Looking at some pics of the axle bearings that come with the EVO V, i noticed there is a golden rim around them,... does it have any special purpose? what is the difference between the golden rim ones and the regular ones?
rcnewb2004 is offline   Reply With Quote
Old 06-10-2006, 09:34 PM   #257
My TRF415MSX also have the same bearings. I don't think they are different but from my experience, they are more durable than the old ones.
trf_racer is offline   Reply With Quote
Old 06-10-2006, 10:25 PM   #258
the bearings in the upright will be the same as the ones in the MSX? that means they aren't as small and won't break as easy as the ones in the EVO IV?
that's awesome!
Old 06-10-2006, 10:41 PM   #259
that's awesome!
FYI, TRF415MSX and EVO4 uses the same suspension system. Same bearings, but gold sheided seems a bit more durable.
Old 06-10-2006, 11:15 PM   #260
hehe thx...
can't wait to get my evo V
Old 06-11-2006, 12:25 AM   #261
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Awesome first day....
the maiden voyage of my Evolution V took flight today. the car is awesome! very free drivetrain and the kit set up (i usually deviate from the kit set up, but this time around i decided to try it) was very very good.
it was a cool breezy day at the Tamiya USA track. The track was freshly sprayed. the track had medium traction. The car had TONS of steering all around and plenty of corner speed. The Tamiya track was ran backwards which meant the end of straight away meant diving hard into Esses instead of the left hand sweeper.
It was very easy to throw the car into the corner, throw it in there very hard and it was still controlled. letting the throttle off a tad bit more and the weight transferred quickly and car rotated. the car ran great with a one-way...and for the spool lovers out there... this car will be simply awesome once you figure out your set up.
Rod... it was too bad you left early. Fred came out and took my EvoV for a spin... and he enjoyed driving it. he threw it into the Esses and it never got upset. Houda took it for a spin too..and seemed to enjoy it also.
i can just imagine the possibilities with this car...
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-11-2006, 12:59 AM   #262
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
If anyone had the option of buying just 2 optional toe blocks for the Evo 5, What would that be? Im leaning towards:
51066 TRF415 SUSPENSION MOUNT (B)
51067 TRF415 SUSPENSION MOUNT (C)
Any suggestions?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-11-2006, 04:26 AM   #263
I think the B,C blocks makes the car very versatile....
I only think about the rear of the car when talking about toe changes... because i think the front toe can easily be adjusted using ur steering rod lengths...
at the rear
Combining B,C,D,E with XA u can have 1.5/2/2.5/3 degree toe in
All the toe you would need in the rear for most tracks i think...
I would do the same given the options.
Old 06-11-2006, 06:44 AM   #264
Default 4.5 in Evo 5
Hi, have anyone tried Novak 4.5R in EVO 5?? I m planning to sell off my Cyclone to get the Evo 5 but from what I heard that belt car are better for mod motors & shaft car are better for stock motors. What problem will I face if put in the 4.5R? Thanks in advance.
hot_version is offline   Reply With Quote
Old 06-11-2006, 07:15 AM   #265
rtypec's Avatar
Yeah, I wasn't feeling it yesterday. We ended up working on my motorcycle and other stuff. Maybe next weekend, I'll have mine ready. I'm going to try to use a spool. By the way the Evo4 spool fits in the bulkheads, I'll see if I can get the gear mesh to work.
To those inquiring about the bearings, the gold-ringed bearings plus the bearing spacer in the hub has help tremendously with the life (errr crash resistance).
rtypec is offline   Reply With Quote
Old 06-11-2006, 12:53 PM   #266
DDC
Default Double diff
Can anyone tell me if it's possible to put a dubble diff in this car. I mustly run on carpet, and the experience a give with oneway is that most cars brake out on the rear. Just to be sure before I buy this car.
Thanks for the reactions,
DDC is offline   Reply With Quote
Old 06-11-2006, 04:17 PM   #267
danjoy25's Avatar
Anything is possible, most of the parts to build a diff comes from existing cars. Just by looking at the posted pics and limited info only the diff halves might be the only new part, but would almost be out within a week after the kit if not the sametime.
Old 06-11-2006, 06:50 PM   #268
rtypec's Avatar
The rear diff could be used in the front as the bulkheads are identical front/rear.
I tried installing an Evo4 spool and it looks like it won't work regardless of all the combinations of spacers that I used. Booo!
Old 06-11-2006, 07:42 PM   #269
Joel Lagace's Avatar
When will the PRO version be out? Like the Shakira edition... Would hate to drop coin on this to see the pimped version come out 2 months from now.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-11-2006, 07:47 PM   #270
Hebiki's Avatar
not sure? almost everything is included the kit already. only thing you can buy are the following:
- aluminum servo mounts
- Ti/aluminum screws
- Ti coated suspension hinge pins
- Ti coated shock shafts
- aluminum shock spring retainers
these hopups (minus the screws) dont add up to much. maybe $30-$40?
Hebiki Design Works
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
