Old 02-02-2014, 12:32 AM   #2011
One question, probably you can check it with your cars.
When I lay my Evo on a flat ground and losen the front topdeck screws, my topdeck is 0,5mm to long. You can see it in the mounting holes.
Do you have the same problem?
JanTRF is offline   Reply With Quote
Old 02-07-2014, 10:57 PM   #2012
Simmi's Avatar
Fist of all thank`s a lot Jan for posting your Setup Sheet
Sorry, but I Need the one with Exotek Chassis and MS Chassis.
No, my Top Deck is ok.
Next few days I Change the Suspension arms, front rear axles and Stabi Set, all from the TRF 418
When ready I post some pics.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 02-08-2014, 07:08 AM   #2013
I think the only thing you have to change is the damper position, so use 3 in front an 4 in the rear. That should be very similar to my normal EvoV damper position.
Use your steering as in the manual.
I changed the front suspension arms back to the Evo V ones, the rear ones fit perfect.
About the lenght of my topdeck. I placed the car on a flat ground.
When I mount the topdeck in the back:
The center mount is ok:
But the front mount is to long, not much, I think 0,5mm (I hope you can see it):
Old 02-09-2014, 04:06 AM   #2014
Simmi's Avatar
My Topdeck fit very nice, hope you can see on the pics below:
Sorry, can not post any pics now
Team Yokomo YZ2 CA
Old 02-09-2014, 04:16 AM   #2015
Simmi's Avatar
The Front Suspension fit, I will see when the 4x8mm screws come.
One question Jan: in Sheets discribes the inner shims with 2, 3 or something. But outside no discribtion? Standart is in the manuel: inner 3mm outside 1,5 mm for example.
How can I see in Sheets wich shims used outside?
Team Yokomo YZ2 CA
Old 02-09-2014, 05:24 AM   #2016
You only need the inner shims describtion.
The suspension is build, that you have to use 4.5mm at all. So the outside is the difference between overall and inside.
If there is a little play, you can shim the outside.
Old 02-09-2014, 11:40 AM   #2017
MikeR's Avatar
Trader Rating: 14 (100%+)
The bottom plate flexes very easy so do not put it on the blocks like you have it. Take the wheels and front bumper off and then put onto a flat set-up board. Make sure no csk screws are sticking out of the bottom plate as well. Then everything will line up perfect
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-09-2014, 12:40 PM   #2018
I had it on a MuchMore Tweak Master. And I used 4 Blocks under the Chassis because of the flex and the Screws.
So that shouldn't be the problem.
When I mount the topdeck, you can also see the gap under the front of the car.
Old 02-10-2014, 09:43 AM   #2019
Jan.. i had the same issue as you have
mine even comes with a black battery holder post - not blue
i don't have my car at the moment so i can't post pictures
i tried to install the tamiya upper deck (std evo5)
front and rear bulkhead holes aligned perfectly
the motor mount holes are the one offset - i think i read this before that they moved the motor mount (not sure though)
you can see the difference if you put both upper deck on top of each other
i'm not sure if you can call this a manufacturing defect
eric
Daghan is offline   Reply With Quote
Old 02-10-2014, 09:43 AM   #2020
Old 02-10-2014, 01:15 PM   #2021
Yeah, they moved the motor mount to use EvoV and MS motor mount. So I can't use the original topdeck.
I think I will send a Mail to Exotek.
Probably I will design my own Chassis.
Old 02-10-2014, 02:46 PM   #2022
Simmi's Avatar
Has anyone the manuel from the exotec Chassis?
Please, I Need help
Team Yokomo YZ2 CA
Old 02-10-2014, 10:57 PM   #2023
Simmi's Avatar
Where do you get the small main gears?
34mm gears it would have to be.
Team Yokomo YZ2 CA
Old 02-11-2014, 01:10 PM   #2024
I use a Arrowmax 86T spur. Xenon fits also.
If you want a smaler gear, you should use Xenon, they have much smaler ones.
Be careful that the spur isn't to small. I bought a 78T, but I couldn' fit it.
Old 02-11-2014, 03:30 PM   #2025
Simmi's Avatar
Xenon VSS DD Spur Gear 64P
Would they fit? It goes from 78T to 96T, see at Tonisport.
For cars 1/12 scale.
Team Yokomo YZ2 CA
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
