Like Tree1Likes
Old 01-13-2014, 11:49 PM   #1996
Blueman Austria's Avatar
Default TB04 Gear Diff build question
Hy there!
I have build up a TB04 Gear Diff for my Evo instead of the Spec Rīs.
I sanded the gears only a bit. Once i have assambled it and filled it up with 3000 oil the diff feels very tight compared to my 417 gear diff filled with the same oil.
I havent it tried at the track right now, but it seems to bee very tight.
Now my question. How much have you sanded yout internal gears?
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 01-14-2014, 12:37 PM   #1997
Normaly I use 1500 or 2000 oil, I don't drive modified, so 3000 is to high for me.
Sanding:
-Small gears
Only short sanding for a clean back
-Big gears
I sanded them a littlebit longer, until the molding noses disappeared
The result was, that I was able to use the small bevel gears with 0.1mm shims.
In my oppinion this diff runs more free than my first one without this modification.
JanTRF is offline   Reply With Quote
Old 01-14-2014, 02:18 PM   #1998
97Clemow's Avatar
Hi, I've built mine with metal gears without sanding any gears and use 1000 oil.
97Clemow is offline   Reply With Quote
Old 01-14-2014, 10:38 PM   #1999
Thx!
I will check it again tonight, if anything is not moving free...
Will report then again!
Greetz Rainer
Old 01-22-2014, 01:30 PM   #2000
Working on the next big thing: Evo IX
A little preview for you. The 418 suspension fits in the rear, the front suspension will also work, but I have to change the shiming.
Old 01-22-2014, 05:22 PM   #2001
Hey JanTRF,
thanks for the info, new susp. looks good. Don't have my parts yet but will soon. Curious if the 418 stabilizer parts will be a direct fit front and rear.
Obsidian is offline   Reply With Quote
Old 01-23-2014, 01:47 PM   #2002
Now it is nearly completed. Probably I will change to split blocks, but I'm not sure.
My next step is to update my electrics and then we will see, how the car works.
Old 01-23-2014, 07:02 PM   #2003
subaru73's Avatar
Trader Rating: 41 (100%+)
Default Evo5
Looking for a replacement lower deck for my evo 5 ms.Just would like to have a spare for my car just in case.Let me know what you have and pictures.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 01-23-2014, 09:34 PM   #2004
Trader Rating: 26 (100%+)
Upper deck:
http://www.ampdraw.com/product/4236/...117-Upper-Deck
Lower deck:
http://www.ampdraw.com/product/4235/...116-Lower-Deck
JoeyE is offline   Reply With Quote
Old 01-25-2014, 12:53 PM   #2005
I think I'm done.
Only waiting for the direct servo horn and the 418 bumper holder.
Probably someone has an good idea, where I could place a fan for the engine.
Old 01-26-2014, 10:16 PM   #2006
Simmi's Avatar
@JanTRF
Can you please post your Setup?
Your EVO Looks great, I love it
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 01-27-2014, 05:00 AM   #2007
Originally Posted by JanTRF View Post
I think I'm done.
If you want lowered shock towers. I mounted my tcxx standard shock towers on it. You can only use (2) screws. But you get more shock adjustment options and lowers the towers quite a bit.
Juan Aveytia is offline   Reply With Quote
Old 01-27-2014, 05:31 AM   #2008
My aim is to get the Evo V MS shock towers, then I can switch between 5 and 5 MS. So I should get the whole range of shock positions.
I have no need for lower shock towers, cause I have no short shocks. (not yet)
Old 01-27-2014, 03:55 PM   #2009
Here is my setup from ETS Hrotovice last november.
It is without the 418 suspension!
I had to add 60g balance weight. 30g in the bumper and 2x 15g under the drivetrain.
Be careful, it is based on an Evo V, not MS!
Old 01-28-2014, 12:10 PM   #2010
Got a TB03D Spool, it fits much better than my Evo4 Spool. Now I can use TB04 gears in the whole drivetrain.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
