Old 10-24-2013, 10:08 PM   #1966
You guys have upgraded the Evo V to Evo VII status already, so Tamiya's Evo VI won't matter at all........
Originally Posted by JimmyMac View Post
Wish Tamiya would come out with an Evo VI....
bertrandsv87 is offline   Reply With Quote
Old 10-24-2013, 10:57 PM   #1967
JimmyMac's Avatar
The problem is that I never bought the Evo V or the Exotek kit for it. I only have the Evo IV. I'd like to see an Evo VI with narrow chassis and new 418 suspension. If I could find a mint condition Evo V and Exotek chassis I might go for it. Oh well... Maybe I'll see if 3Racing comes out with a narrow chassis for the TB04. I'm sure they would build a better motor mount.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-24-2013, 11:28 PM   #1968
The only concern with the Evo V to me is weight.... If you stay under 1410grams, you're light enough to take on the competition... The chassis is thin enough: it looks to be under 100mm wide and very sturdy.... I say it's up to the driver at this point.... Lots of Pro4's have been beating newer designs, and so can the EVO V.... Parts though are another matter....lol...
Old 10-25-2013, 12:51 AM   #1969
My Evo V has a weight of 1320g with a heat sink on the engine.
But the driver...
Do you have any problems with the Lipo touching the top deck? I think, there is not much space.
@ JoeyE
Isn't the rear shaft, with the bevel gear, touching the gear diff? I had to shorten it a little bit.
JanTRF is offline   Reply With Quote
Old 10-25-2013, 02:58 AM   #1970
Trader Rating: 8 (90%+)
Wasn't Travis S selling his second TB EVO V MS just a couple weeks ago
TenzoR is offline   Reply With Quote
Old 10-25-2013, 03:00 AM   #1971
Originally Posted by JanTRF View Post
@ JoeyE
JoeyE has an EVO 5MS, IIRC it's slightly different.
Old 10-25-2013, 06:32 AM   #1972
Trader Rating: 24 (100%+)
But the driver...
@ JoeyE
The rear shaft touch a tiny bit due to the gear diff cover no being perfectly round. There is a high spot. but other tan that, not bad.
My battery fits perfect under the top deck without a problem.
JoeyE is offline   Reply With Quote
Old 10-25-2013, 11:22 AM   #1973
Ok, I have the same touch like you. I think after the first run it will fit :-)
And there is no big difference between V and MS gear box. The only difference is the rear shaft and it has the same shiming in both cars.
Old 10-25-2013, 06:12 PM   #1974
I am running a TB03 spur gear holder. Had to shim it and shave a little off. But it centers the spur pretty good. There are about 5 races on the spur gear holder now and it's holding up pretty well.
Old 10-26-2013, 10:31 AM   #1975
Ok, you managed it to use the spool with 40/16.
Do you use the TB03 Spool? I use a Evo IV Spool, that could be my problem.
Old 10-26-2013, 06:12 PM   #1976
I also use the Evo IV spool. But I use tiny washers to fill the little gap on the gears back side to the spool. Then it sits nice and flat. The washers are tiny.
Old 10-27-2013, 04:08 AM   #1977
Ok, I will try it again.
Old 10-30-2013, 04:22 PM   #1978
Ok, it works, but only with the 16T-bevel gears of the Evo.
The bevel gears from the TB04 won't fit in my car.
Old 10-31-2013, 02:16 AM   #1979
97Clemow's Avatar
Hi, just did this in the workshop.
Used an Evo 4 17 tooth bevel pinion gear instead of the Evo 5 16 tooth bevel pinion gear to get the internal ratio from 2.437 to 2.294.
Enlarge the center hole of the Evo 4 pinion gear to 3mm with a small round file.
Then finished of the face where the e-clip holds the gear to the input shaft till there was enough clearance to fasten the clip on and re-shimmed the shaft and diff to get normal clearance
The bevel pinion on the left in the pictures is the 17 tooth Evo4.
I'm not sure if this helps anybody out a great deal but fixing up the pinion only takes ten miniutes.
Tamiya TB Evolution V-tb-gear2.jpghtmlIMG]
97Clemow is offline   Reply With Quote
Old 10-31-2013, 05:35 PM   #1980
Then finished of the face where the e-clip holds the gear to the input shaft till there was enough clearance to fasten the clip on and re-shimmed the shat and diff to get normal clearance
.Attachment 1128606
Attachment 1128607
Attachment 1128608
Attachment 1128609htmlIMG]
Thanks for the info~!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
