Old 10-22-2013, 06:43 AM   #1951
Trader Rating: 24 (100%+)
Originally Posted by Chrissy C View Post
Juan (or anyone else!), did you get the TB04 gear diff yet? Hows the fit in the EVO bulkheads?
Cheers,
Chris
I got mine yesterday but haven't tried installing it yet. At least its sealable.
JoeyE is offline   Reply With Quote
Old 10-22-2013, 07:06 AM   #1952
Chrissy C's Avatar
Thanks JoeyE, look forward to hearing the results.
Chrissy C is offline   Reply With Quote
Old 10-22-2013, 08:52 AM   #1953
Cheers,
Chris
Not yet. Waiting to order parts. I'm sure it will fit without the diff covers
Juan Aveytia is offline   Reply With Quote
Old 10-22-2013, 02:00 PM   #1954
Yes, the TB04-Diff fits perfect, I had only changed the shiming.
You can run the Evo with 39/16 and 40/16 internal ratio, but I wasn't able to use the Spool with the 40, so I build my car with 39/16.
I hope Tamiya will bring alloy outdrives, that's the only thing I'm missing.
Here you can see my car for ETS Hrotovice:
And the TB04-Diff in my Evo5:
JanTRF is offline   Reply With Quote
Old 10-23-2013, 03:24 AM   #1955
Chrissy C's Avatar
Thanks JanTRF, great news. Its good that you can use the standard 39t gear, i thought you would have to swap out the pinion gear as well, but having looked at the manual i can see how it all works...well done Tamiya!
Just ordered the parts from Banzai.
How does the diff feel straight from the packet?
Old 10-23-2013, 04:55 AM   #1956
Blueman Austria's Avatar
Where is the manual from the TB04 available?
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 10-23-2013, 05:12 AM   #1957
Chrissy C's Avatar
Rainer, Tamiya USA have them to download.
Old 10-23-2013, 05:23 AM   #1958
Found it already thanks!
Wich material are the outdrives 51554? Aloy?
Greetings Rainer
Old 10-23-2013, 05:28 AM   #1959
Chrissy C's Avatar
A few posts above JanTRF says that he would like to see alloy outdrives as a hop up, i think 51554 will be the usual Tamiya steel. Blades aren't used which is a pain as the steel will groove quite quickly. Looks like the dremel will be required!
Old 10-23-2013, 05:35 AM   #1960
The description at rcmart says material alloy...
But i also think it will be steel, but as you said without blades...
Old 10-23-2013, 09:45 AM   #1961
The outdrives are heavy, they are steel!
The diff feels good, but my 417 gear diff is also new and runs better.
But that could be, because I wanted to try the fitting in my Evo and build it in a hurry.
I also used the plastic cross-shaft for the bevel gears, it isn't a good fit. I will order 54533 asap.
What do you think about the use of ballbearings for the outdrives. Less friction, but also less sealing...
Old 10-24-2013, 08:21 PM   #1962
Just installed the TB04 gear diff. Not much shimming. Hope to have time this weekend to try it out.
Rear:
Front:
Old 10-24-2013, 09:06 PM   #1963
JimmyMac's Avatar
Wish Tamiya would come out with an Evo VI....
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-24-2013, 09:16 PM   #1964
I hope they come out with metal gears. I noticed that the metal cross pins are available.
Old 10-24-2013, 09:52 PM   #1965
TAMIYA TB04 hop up gear diff parts:
54540 metal gears (I don't see it for sale yet)
54533 metal cross pins (available now)
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bullet100
