Old 12-02-2012, 08:23 PM   #1771
cheehtae's Avatar
Trader Rating: 15 (100%+)
anybody has an evo 5 ms for sale? not to pricey please.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-03-2012, 01:12 PM   #1772
great explanation.
sahil is offline   Reply With Quote
Old 02-19-2013, 12:32 PM   #1773
Trader Rating: 26 (96%+)
do any of the square size lipo fit in this car, like the orion carbon edition 5000 or similar ,I can buy a new tb evo v, but wanted to know if the battery fits thanks
zaraz is offline   Reply With Quote
Old 02-19-2013, 12:53 PM   #1774
Yes they do. And possibly exoteck is making a chassis for it
Juan Aveytia is offline   Reply With Quote
Old 02-19-2013, 01:01 PM   #1775
thanks, the top deck does not come in the way height wise, and can you use the battery holder of you have to tape it
Old 03-18-2013, 08:46 PM   #1776
MikeR's Avatar
Trader Rating: 14 (100%+)
Finally ready!
Exotek EVO5 Pro Chassis
http://www.exotekracing.com/evo5-pro...rsion-limited/
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-18-2013, 10:12 PM   #1777
Thank you Mike! Bought 3!! Can't wait to try it!!
seasons29 is offline   Reply With Quote
Old 03-18-2013, 11:24 PM   #1778
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
brought one too..why 3?
OVA is offline   Reply With Quote
Old 03-19-2013, 07:58 AM   #1779
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
If anyone has an EVO V they are looking to part with, please let me know. Not looking for a NIB collector car, as it will be raced .
Thanks,
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 03-20-2013, 03:07 AM   #1780
Blueman Austria's Avatar
Default Exotekconversion Spur Gear Advice
Hy there!
Ive also purchased an Exotek Conversion, and now im searching for a matching Spur Gear in 64dpi size.
Does anybody know wich 64dpi Spur is simmilar to an 60T 48dpi?
The duometer of the spur should be max. 340mm
Found a CRC 72T 64dpi here!
http://www.stormerhobbies.com/cgi-bi...ns&pn=CRC64172
I think it would fit, but i dont know if the gearing with an 39T pinion will match the motor mount holes?
I need to gear at max. 4,5 FDR. So 72/39 will give me exactly what i am looking for.
Thanks in advance
Greetings Rainer
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 03-20-2013, 04:03 AM   #1781
Thumbs up
[QUOTE=Blueman Austria;11951376]Hy there!
To calculate the equivalent number teeth in a 64 pitch to 48 or visa versa. Simply divide the number of teeth by its pitch.
Then multiply that number by the target pitch to get the equivalent number of teeth.
Example: 108 Tooth 64 Pitch =
81 Tooth 48 Pitch
108/64 X 48 = 81
Clear as mud!
Ordered one also. Happy Birthday to me!
TBOTubed is offline   Reply With Quote
Old 03-20-2013, 06:04 AM   #1782
[QUOTE=TBOTubed;11951435]
Originally Posted by Blueman Austria View Post
Hy there!
81 Tooth 48 Pitch
108/64 X 48 = 81
Clear as mud!
Thanks !!!!
Next thing i recognized about the new chassis, it will be tough to install the electronic properly...
My LRP SPX Zero is not the smallest... and with only 84mm chassis width it will be very very thight...
Greetings Rainer
Old 03-20-2013, 01:41 PM   #1783
OVA
OVA's Avatar
I want to rebuilt my EVO5MS Drivetrain..where can I buy the propeller rear shaft and spur holder for EVO5MS,
the standard EVO5 will not works they are differnt parts..
Old 03-20-2013, 02:17 PM   #1784
daktulos's Avatar
Hi, the parts are not available and I am in the same boat as you...
My solution for the small slope I have in between the shaft and spur holder is to put Shoe Goo (Goop) to fill the void...really a small amount ! You need also to let it fully cure to make the bound strong. The good thing with that stuff is that it's really easy to take it out after for maintenance...
It work for me very well in 17.5T and stay strong for more than 25/30 packs or until I decide to clean/lubricate the bearings !
Hope this will help !
Alexandre
daktulos is offline   Reply With Quote
Old 03-20-2013, 03:09 PM   #1785
daktulos's Avatar
Hi, here are some measurements with some spur I have...
Kimbrough 64P
88T=35.50mm 86T=34.65mm 84T=33.80mm
PRS 64P
82T=33.30mm 78T=31.70mm 77T=31.30mm 76T=30.95mm
Xenon 64P
88T=35.87mm
You can notice small size difference between company...
The thing to consider also is with spur this small is that the screw may interfere with the outer lip of the spur.
Nothing imagination a file and shims can do
With my 17.5T I will probably start with the 82T PRS spur and a 48T pinion.
I have a lot of room with this setup.
With the 82T PRS spur I can even fit a 42T pinion for a 4.76 ratio !
My Exotek EVO 5 chassis is on its way !!!
See you !
Alexandre
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
