Tamiya TB Evolution V
#1651
One thing I notice the 416 has more steering than Evo 5.
#1652
I run the hell out of mine. I find its better than my 416 in 17.5. Both cars are nearly two years old now. I just got back into racing after a bit of a break. Both are competitive, but I do better with EVO V.
Waiting on getting an additional newer speeder to have better match instead of switching back and forth a borrowed speeder. Right now I have sphere, and borrowing a sxx tc. Hopefully a sxx stock spec or an Orca
See my EVO set up here if you want. I have the 416 uprights and ft knuckles, but rest is all EVO V.
http://www.teamtrf.com/forum/viewtopic.php?f=12&t=37
I also prefer my Evo5 for 17,5T BL class racing !
I race mine with the original uprights. He only thing i have modded on my car is the front steering. i cutted off the steering posts just above the arms, an linked them with a selfmade carbon brace. Looks good!
I will post a pic later.
Greets blueman
#1653
Greets blueman
Greets blueman
#1654
#1656
#1657
Hi,
Need some tips for a friend who use Evo5 MS.
He still have differential problem... must rebuilt it each run (carpet racing)
(Diff plates polished with 1000 waterpaper, tungsten ball, asso black & white grease)
Wait for answer....
Wait for answer....
#1659
He have 3 diffs...
One with ceramic ball (other with tungsten)
All parts are new and still the same...
#1660
it sounds like he knows what hes doing when it comes to ball diff assembly, but I have never heard of a problem like this. Try installing one of those diffs in someone else's car if they are kind enough to allow you to.
If its it lasts a while then its another issue.
How tight is the diff? I run mine as loose as possible without any slip.
#1661
#1662
Anyone run the EVO V down at 1350 or 1400g if so how did it go ?
#1663
kit
where can I buy a tb evo 5 ms kit from?
#1665
it's not just the weight, u can do this by adding subtraction. one thing is motor in use & gearing set according to track. else u will have torque steer. with the correct setup the car runs beautifully...
