Like Tree1Likes
Old 10-30-2008, 12:16 AM   #1546
Blueman Austria's Avatar
My setup for a tecnical med-high grip carpet track:
Motor: LRP 13,5 Erasor "Stock Spec" (Has a sintered Rotor) with 6cells
One way,
Chamber 1,5 F+R
Castor 4
Ground clearance : 5mm Front, 5,5mm Rear.
Droop, 6mm front, 5mm rear.
No Suspension arms (Rollcenter)-spacer
Block combo: Front D-D, Rear A-E (2 toe in)
The upper arm mount on the bulkhead i used the inner hole F+R.
Damper positions: F hole 2, R hole 3.
Medium swaybar F+R.
I also use 3 center posts for carpet.
Dampers:
50 oil (Tamiya Green) F+R
Tam. White F
Tam. Blue R
No O-Rings or Rebound foams
I also build the dampers without rebound
The rest shimms and positions are al like in the manual.
Tyres: Vtec 27R with JB "blue,Yellow,blue" foam inserts.
Body: HB Mazda6.
These are my favorits for Carpet Racing
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 10-30-2008, 08:16 PM   #1547
Thanks guys...I appreciate the input on setup. I'm going to experiment with the rear toe and the roll-centre and see what seems to work best.
I have my first series race next weekend so I'll see how everything works!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 11-02-2008, 01:56 AM   #1548
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
For those who may be interested, Tamiya will be releasing a spool that is designed to be a direct fit into the both EVO5 & EVO5 MS!
The part number is 54125.
rctouringracer is offline   Reply With Quote
Old 11-02-2008, 12:10 PM   #1549
Originally Posted by rctouringracer View Post
For those how may be interested, Tamiya will be releasing a spool that is designed to be a direct fit into the both EVO5 & EVO5 MS!
Good news...
A TB-03 Spool from 3Racing should also be compatible... ...I am running Tamiya's Aluminium TB-03 Differential in my Evo5 as the original outdrives worn out - the measurements are equal.
Tommi.
TommyW is offline   Reply With Quote
Old 11-11-2008, 08:25 AM   #1550
When ? I have an EVO V sitting around unused just waiting for a spool.
weekendracer_uk is offline   Reply With Quote
Old 11-11-2008, 10:00 AM   #1551
Wish I knew, seems as though with the economy slowing to a crawl so has the release of new tamiya parts....
Old 11-24-2008, 02:34 PM   #1552
Guys, seriously need your help. I have asked on the TB-03 thread, but not had any help as yet. Seriously struggling with torque steer coming out of left hand corners.
Coudl you guys share a setup, 10.5 or 19t, pref carpet base, thanks!!
DA_cookie_monst is offline   Reply With Quote
Old 11-24-2008, 05:19 PM   #1553
neil4wd's Avatar
Trader Rating: 20 (100%+)
Hi all! Could I trouble anyone for EVO5 MS settings for an indoor asphalt track? I'm currently running mine using the manual's settings with only the following changes...
  • front/rear camber (-1.5deg)
  • rear toe in (1deg)
  • front toe out (1deg)
  • wheelbase shortened by moving the front lower suspension arm back by 1mm
...everything else as mentioned is based on the manual.
Other details...
  • motor: HPI S40 23T
  • tires: Sorex 36/soft inserts
  • body: Tamiya Legacy
  • ride height: 5mm
With this setup I'm getting a "push" powering out of corners.
I know I can "cure" this by changing a host of things like droop, camber, springs, damper location etc. but I'm not sure where to start and a tried and tested setup would help a lot to point me in the right direction.
Many thanks for any help.
Look ma! I sold all my RC stuffs. :lol: Now I bought NEW ones!! :lol: :lol: And here come the credit card bills. :(
neil4wd is offline   Reply With Quote
Old 11-25-2008, 09:12 AM   #1554
Man I can't really help you, I race 13.5bl. I suggest you try checking your droop and the balance from left to right on the car.... I know the vehicles is more than likely new, but you may want to clean out all the bearings and relube them. I don't own a TB03 presently but I would check to see if the motor mount flexes in the chassis.
Old 11-25-2008, 10:16 AM   #1555
everything is free and running, I am sure there is no flex in the motor either, driving me nuts, I want to run the car, but the racing is close where we are, and I can't carry a poor car at all, Shaft drive is soooo appealing!!
Old 11-25-2008, 01:24 PM   #1556
The may not be able to handle a motor as torquey as a 19t motor, maybe you should consider moving over to a 13.5bl motor, I've been told the brushless motors work better in shaft cars?!? Something about the way the censored bl motors deliver there power & the way shaft drive cars lay down the power. Maybe someone can explain that better so everyone can have a better understanding. I had to turn down the initial power delivery on my speed control to get my car to accelerate smoothly, that eliminated all torque steer & my car still out accelerates all the belt cars I race against.
Old 11-25-2008, 01:58 PM   #1557
Rogier's Avatar
The spool that Tamiya is bringing out for the TB-03 should also fit in the Evo 5 MS. But when Tamiya will release it..... dunno. BUT... .I just saw a 3 racing spool for the tb-03, so this one should also fit in the evo 5 MS. Check http://rcmarket.com.hk/product_info....8p30p5d6e3g7c2 Pretty cheap..... know it's not blue.... But you can drive! So bring on the Evo 5s en evo 5 MS....
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 11-25-2008, 09:48 PM   #1558
Cheers buddy
I will give that spool a go in the EVO V and if it does not fit right im getting myself a TB-03
Old 11-26-2008, 03:00 AM   #1559
Rogier's Avatar
Cheers buddy
If you tried it, let us know! Not having a spool available for the Evo 5 MS is the main reason I didn't buy one yet.
Old 11-26-2008, 05:44 AM   #1560
Will find out before to long as i have just gone and ordered the TB-03 spool from 3racing.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
