Like Tree1Likes
Old 09-11-2008, 06:42 AM   #1531
mzack11's Avatar
hello to eveyone, i would to ask about ball diff for evo V, can it fit to evo IV??? thanks...
mzack11 is offline   Reply With Quote
Old 09-11-2008, 09:47 AM   #1532
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Doesn't look like the EVO 5 diff will directly fit into an EVO 4 diff housing.
Completely different in width and the ring gear is different as well.
rctouringracer is offline   Reply With Quote
Old 09-13-2008, 11:17 PM   #1533
808TXT1's Avatar
Anyone know where I can buy a diff for the EVO 5??
thanks
808TXT1 is offline   Reply With Quote
Old 09-14-2008, 10:48 PM   #1534
Blueman Austria's Avatar
thanks
A complete diff is not available. You have to buy the parts seperatly.
Take a look at your manual for the numbers.
I think rcmart.com is a good adress to search.
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 09-15-2008, 12:12 PM   #1535
Evo V outdrives fit in the IV. You can use every part in the V diff, but you will need the IV gears. On the IV diff, the shims go on the longer outdrive, but when you use the V diff, you need to shim up the short one.
slomo is offline   Reply With Quote
Old 09-18-2008, 02:42 PM   #1536
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
hey guys,
im currently in them middle of rebuilding my evo after not racing it for 6months.....
any build tips?
much appreciated
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 10-24-2008, 09:26 AM   #1537
Just rebuilt my EVO and my problem area was and still is my rear hubs!
The bearing in the hub continue to fail creating drag!
Other than that the car is great & I have got it dialed in to carpet race....
If anyone is interested in my set-up just let me know.
Old 10-24-2008, 09:45 AM   #1538
I'm just finishing rebuilding mine for our silver-can "GT" class in our WCICS series. I'd love to get yours or others' ideas for setup on low to medium grip carpet using the new Jaco Blue rubber tires.
Thanks,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-26-2008, 05:45 PM   #1539
WC
WC's Avatar
Trader Rating: 28 (100%+)
950 BBs are evil assume you've got a stock evo5
should consider changing to TRF416's knuckles & hubs which use 1050 BBs, just like the evo5ms
my TB03 also uses 1050s
WC is offline   Reply With Quote
Old 10-26-2008, 07:03 PM   #1540
Since i use the bearing spacers between, i have no problem at all with the bearings. Now they are very relayable.
Think this is a must have tuning part
Greetz Blueman
Old 10-26-2008, 10:23 PM   #1541
waOscar's Avatar
Greetz Blueman
Agree 100%
950 Bearing Spacer is a must run!
I used more bearings in the first 6 months without bearing spacer than I have in last 2 and 1/2 years with spacers and thats in two cars with TRF suspension.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 10-27-2008, 12:48 PM   #1542
I use the bearing spacers.
I think the 1 aluminum hubs may have something to do with my continual bearing failure.
I will post my lastest set-up today after I finish taking notes from this past weekend's club race.
Old 10-29-2008, 02:13 PM   #1543
Sorry, can't get my scanner to work. But here are my settings.
Track: Nexus Indoor Carpet
Track Condition: Mid-High Traction with groove
Front:
Upper arm position on bulkhead 1
Upper arm spacer on bulkhead 3mm
Damper position on tower 2
Suspension mount spacer 1.5mm, front & rear
Damper position on suspension arm 1
*Used original LWT arms for more stability
*Used 46mm steel axles
Front droop 5mm
Front Caster 4
Camber -2
Ground Clearance 5mm
Front Drive Direct
NO stabilizer
No wheel spacer
Urethane bushing in damper 1
Damper piston 3 hole
Damper oil 40wt Associated
Damper Spring Tamiya Blue *from the original tuned spring kit*
Front toe angle +1
Front suspension mounts D front, A rear
Front suspension arm spacer 3mm
Ackermann spacer 3mm
Steering knuckle Ackermann position 2
*used stand 5.5mm ball stud in steering knuckles with no hex head
Rear:
Upper arm spacer on bulkhead 1mm
Damper position on shock tower 2
Upper arm position on rear carrier B
Upper arm Spacer on carrier 2.7mm
*used original LWT suspension arms for stability
*used 46mm aluminum axles
Rear droop 6mm
Rear axles -1 aluminum carriers
Camber -2
Ground clearance 5.25mm
NO stabilizer
No wheel spacer
Damper spring Yellow kit spring
Rear toe angle -3
Rear suspension mounts X front, D rear
Rear suspension arm spacer 1mm
General Settings:
Motor 13.5BL Novak
Battery LIPO
Body DNA 1
Wing STD
Tires Sweep 28LP
Wheels Proline AXIS 26mm
Tire Insert Sweep Medium
Time for more R&D!
Lets get a look at what you guys may have come up with......
I have found this set up have an aggressive but controllable turn-in but the mid-corner steering could be a little better, still working on exiting speed. The rear is getting better but use some improvement, but is more settled than in the past.
Last edited by rctouringracer; 10-29-2008 at 02:21 PM. Reason: miss spelled word & add photo
Old 10-29-2008, 05:42 PM   #1544
rctouringracer,
Thanks for posting the setup. If you don't mind, I had a couple of questions for you regarding a few items in your setup (keeping in mind that I'm pretty new to TC racing!)
I always thought (or was led to believe) that 3 degrees of rear toe was excessive and simply robbed straight-line speed. What's the rationale for this?
I'm assuming that raising the suspension mounts by 1.5mm raises the roll-centre. What impact does this have on the car?
Everything else seems pretty similar to the base kit setup. I only have the front one-way (or diff) and I'm going to be running a silver-can motor on low-ish grip carpet. Is there anything else I should keep in mind for this?
Sorry for all the questions and thanks in advance for any help anyone can provide me with
Cheers,
Mike
Mike
Old 10-29-2008, 08:22 PM   #1545
The 3 of toe-in in the rear is right at the limit of the amount of toe you would ever want to put into that setting.
I admit it seems a little excessive but so far the set-up is working for me. I had it 2 before and the rear was unsettled going down the straightaway at my track. The new setting has worked so far.
The roll center change has made the vehicle be able to carry more speed around the corners, the EVO seems more planted through the infield.
Remember I am running a 13.5 BL motor, if your running a less powerful motor you may not need to set your toe as aggressively as I did. The outside track I was going to did not have a straightaway as long the carpet track I am presently running at & I didn't need 3 of toe.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
