Like Tree1Likes
Old 08-07-2008, 10:42 PM   #1516
Blueman Austria's Avatar
I ran mine with the oneway all the time
Only on carpet with 17T or 9,5T BL motors the spool handels better, but for usual i run it with my 13,5T BL LRP Eraser "stock spec" motor, and therefor the laptimes with a oneway are faster. (tarmac and carpet).
When i use the spool i cant change my driving style so fast that i can use the advantages of the spool, so it is like i write above.
I am a onewayguy
BTW: Anybody already race an MS kit?
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 08-08-2008, 05:34 AM   #1517
Send a message via AIM to GuyIsDamGood
Hey Blueman;
I thought a 1-Way and Carpet Tracks aren`t good.....it gives too much steering.....?. . . . .But it should be alright since you have that Foam Tire traction to slow-down.
-Believe me; using a Spool is the way to go on Asphalt.
I`m thinking about LOCKING the 1-Way.....There will never be a Spool made for the Evo 5.
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 08-08-2008, 11:20 AM   #1518
Don't think a spool is a good idea for a shaft car... like there is nothing to absorb driveline shock.
redbones is offline   Reply With Quote
Old 08-14-2008, 04:51 AM   #1519
m3ndo5a's Avatar
I run either a Spool or One way for the evo5ms
If the track is open or high traction minus brakes I would run the One way.
If the track is tight and requires brakes for 180* I would run the Spool.
Most kit are base on a oneway. Yet today kits are now coming out with a $3 dollar spool with the same high price tag.
The EVO5ms has alot of steering even with a spool the roll center demands alot of up front grip......I normally remove shims from the front inner camber link to tone the car steering down.
m3ndo5a is offline   Reply With Quote
Old 08-15-2008, 10:33 AM   #1520
Ok just getting back into racing and building my EVO V which i brought when it first came out, question is where can i order a spool or a complete diff ? running a oneway at my local out door track is just not an option.
No time to read past posts so sorry if this have been answered before.
weekendracer_uk is offline   Reply With Quote
Old 08-21-2008, 09:35 PM   #1521
adrictan's Avatar
What spool are you using? Will the Evo IV spool work for the Evo V ms? What's the part number?
adrictan is offline   Reply With Quote
Old 08-22-2008, 09:22 AM   #1522
This could solve spool problem:
http://www.3racing.hk/products.php?products_key=3470
I cannot confirm its compatibility - but since the gears are the same in TB03 and EVO5, everything depends on the width of bulkhead...
TommyW is offline   Reply With Quote
Old 08-22-2008, 12:20 PM   #1523
mac853's Avatar
You should be careful, most time this situation barely not work.
Don't remember TA05 and TRF415MRE use same pulley, but never the same diff hub, one way nor spool.
I think you have to make sure to be better.
Adric, i have replied your question in another thread.
Maybe it could solve your problem.
mac853 is offline   Reply With Quote
Old 08-23-2008, 08:26 PM   #1524
Metla's Avatar
Originally Posted by seath79 View Post
We run about 7.5 ratio for a shorter tighter track, something like 96/30 or 90/28.
Cheers for the reply.
The locals aim for a ratio of 4.0, anyone have a suggested pinion/spur combo to achieve that?
Metla is offline   Reply With Quote
Old 09-08-2008, 07:57 PM   #1525
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Need a basic carpet set-up to start my carpet racing season. I have never used my EVO 5 on carpet.
I will be using a 13.5, lipo & rubber tires.
I would like tire & body suggestions also...
Thanks in advance guys!
rctouringracer is offline   Reply With Quote
Old 09-08-2008, 11:34 PM   #1526
7.5 on silver can would be reeeaaaalllly slow.
slomo is offline   Reply With Quote
Old 09-09-2008, 09:04 AM   #1527
Hello anyone running their EVO 5's on carpet out there?!?
Old 09-09-2008, 03:53 PM   #1528
Hy!
My basic carpet setup is:
Dampers:
3-hole plates, 50 oil al around, white springs front, blue rear.
Chamber: 1,5 f+r
Chastor: 4
sway bars: front hard, rear medium (or f+t medium. depends on the grip level)
Toe blocks: front D+D, rear A+E (for 2 toe in)
no shims under the suspension blocks.
The inner holes on the bulkheads all around.
ride height: 5/5,5 mm
Droop: front 6mm, rear 5mm
The rest of the car is shimmed per manual.
Hope that helps you,
Greetz Blueman
Old 09-09-2008, 03:54 PM   #1529
One thing i forgot on the dampers:
build it without an o-ring or urethane bushing!
Old 09-09-2008, 04:41 PM   #1530
Thank you Blueman!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
