Old 07-05-2008, 10:01 AM   #1501
C van der Hagen's Avatar
Originally Posted by bender View Post
The rear input shaft and gear holder assembly on the Evo V Ms are all new.
The gear holder has it's own shaft which interlocks with the rear input shaft.
This allows you to remove the spur gear assembly without effecting or removing the rear input shaft.
This doesn't explain why the front one way is different...
C van der Hagen is offline   Reply With Quote
Old 07-05-2008, 07:08 PM   #1502
adrictan's Avatar
So will the Evo IV Front one-way fit the MS kit?
adrictan is offline   Reply With Quote
Old 07-06-2008, 01:47 AM   #1503
EVO 5 & EVO 5 MS share same one-way unit: Tamiya #3455960.
Since the the bulkheads and the gears are the same in both cars also the one-way unit of TB03 should fit in MS if Tamiya has announced compatibility with standard EVO 5...
TommyW is offline   Reply With Quote
Old 07-06-2008, 04:10 AM   #1504
jarkkom's Avatar
Send a message via MSN to jarkkom
Originally Posted by m3ndo5a View Post
I have a mean Set up on the car
Please post your setup.
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 07-06-2008, 05:19 AM   #1505
hobbipro's Avatar
Trader Rating: 21 (100%+)
I've been able to locate a EVO IV front spool in Germany, but the model shop refuses to ship to US Guess the only hope now is that Tamiya re-releases it for the EVO V MS.
hobbipro is offline   Reply With Quote
Old 07-06-2008, 08:19 AM   #1506
Blueman Austria's Avatar
Scrub off is normally found going through a sweeper or making a turn. That has everything to do with how soft your car is or how much steerting rate you are using. I think my car is good.....no need to fix that it will make the SHOW.
The Point I was making that is being a "shaft drive" and not changing the ESC profile the brakes are much stonger than my belt cars....the tires, shock dampen, shock mount, droop, slight camber and drivetrain has something to do with brakes not just the ESC......if you tighten the tension on a belt kit the brake will be alittle strong but you risk eff% and your belt may "break" under pressure. Hint Hint.
Also,scrub off speed, track times or lap times is what determine the the loss of performance. Which in this case the car is 3tenth faster around the track.
....................................that enough to make everyone go re-wrench and bring out new tires..
The torso flex helps the car stick hard. And the fact that I have a mean Set up on the car......next time I will say "Dailed"......800collect..Yes I will accept charges it was good eveywhere on the track.
About the spool if you can find an evo4 spool get it, it will work in the EVO5 or 5MS.
I will get more pictures track side...
Hey m3ndo5a, is it possible to change the spur only with removing the rear alu brace, or must you also remove the top deck?
I plan to install the new rear drivetrainparts (little rear bevelgear shaft, spurgear holder, rear center cup, and the new motormount with the little plate wich is holding the bearing) but i want still use the old upper deck.
Think this should work, because the holes in the lower deck for the motor mount are located in the same area.
Greetings Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 07-06-2008, 06:17 PM   #1507
m3ndo5a's Avatar
Blueman
I am not sure you can use the Top deck of the EVO5 with 5MS....
More than likely you will have to get a 5MS top deck because of the new Motor mount.
Changing the spur gear is so easy....it the best thing every for a shaft car.
I will post my set up later.
m3ndo5a is offline   Reply With Quote
Old 07-13-2008, 04:18 PM   #1508
Does regular spur gears like xenon, kimbrough fit the new spur gear holder?
Old 07-13-2008, 06:26 PM   #1509
Yes they fit with no problems.
slomo is offline   Reply With Quote
Old 07-13-2008, 06:51 PM   #1510
Trader Rating: 14 (100%+)
Hi,
I'm going to be selling my EVO 5 soon as I never get a chance to race it. (so far once, silver can) it has a front diff, one way, spare arms, extra hinge pin blocks and alot more. has the light blue diff covers on it too.
it is built right. per the build up on Tamiya's site.
I will email pics to anyone interested.
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 07-28-2008, 02:38 AM   #1511
Metla's Avatar
Can anyone suggest a suitable spur/pinion combination for running in a silver can class?
Metla is offline   Reply With Quote
Old 07-28-2008, 04:02 AM   #1512
seath79's Avatar
Default Gearing
We run about 7.5 ratio for a shorter tighter track, something like 96/30 or 90/28.
seath79 is offline   Reply With Quote
Old 08-01-2008, 12:29 PM   #1513
Send a message via AIM to GuyIsDamGood
Hey Evo 5 Guys;
I finally got the chance to Race My Evo 5 in a Real Race at the Floyd Bennett Track(against good drivers with pro kits)-(Friday Morning July 25th) --All using 19-Turn Motors. The(My) Evo 5 has good Steering, it Runs Straight(with Front and Rear Ball Diffs).....but it needs a SPOOL(It needs one bad.). I`ve never realized it before. It also has some Oversteer on the loose turns.
-----I`ve ran My Pro 4 with the Spool installed (that same day same track) and it out drives My Evo 5.....I was faster with the Pro 4 by 3 seconds.
To think about it:
-My Evo 5 cost me over $1,275(fully Hopped-Up including electronics).
-I don`t want to spend that amount on another kit that doesn`t have the part(s) that keep it from running it`s best.
-If the Evo 5 MS doesn`t have a Spool.....I`m NOT getting it.
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 08-02-2008, 08:04 PM   #1514
hobbipro's Avatar
I wish they would include a spool in the high end kits too, I gave up looking after finding some in Germany, but they will not ship to the U.S. I'm going to try these: http://www3.towerhobbies.com/cgi-bin...&I=LXJK92&P=ML
They are 3mm so they will fit where the diff balls go. Hopefully cranking down on the diff screw will keep it from slipping in all but the most stressful situations. The one losi has for the Jrxs is basically a piece of plastic in the ball diff holes, against the diff rings. It allows it to slip if the front end binds up in an accident. Hopefully these pegs will accomplish the same thing.
Old 08-07-2008, 07:48 PM   #1515
It`s up to you guys to put whatever you want in/into/on your kits; but I`m not goint to install anything that isn`t totally made for the kit.
I ran(raced) My Evo 5 that day with most of the Stock Set-Up on a somewhat opened-out track and it was loose in mid-turns.
-I know some Droop or Shock Placement or a Spring Change would fix the problem; but a Spool will cover those fixes.
I`ll list My Set-Up when I find My Set-Up Sheet Book.....Ha Ha!
Take Care
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rccartips
