Old 01-21-2003, 09:16 AM   #121
KINGZJ's Avatar
Send a message via AIM to KINGZJ
The track I race on is fairly large (for a indoor carpet track) and with a monster stock motor I am geared at a 7.8 or a 8. I generly run either a 125 or a 128 tooth spur gear.
KINGZJ is offline   Reply With Quote
Old 01-21-2003, 03:13 PM   #122
Steevo's Avatar
Default Re: Just got
Originally posted by Mike F
my 04R . Haven't put it together, going to order some hop ups before I get started on it. The chassis is nice and light
How do you like the new TA04R Mike?? Did you get it from Andy??
Those shocks are so smooth and the carbon reinforced Tub chassis is excellent. Just watch out for some minute shorting on the chassis when using the saddle packs. You will have to use some insulation to stop it.
Steevo
Steevo is offline   Reply With Quote
Old 01-21-2003, 03:19 PM   #123
Regional Moderator
Send a message via AIM to Mike F
Didn't get it from Andy but I will be getting my hop ups from him. I think I'll hold off on the chassis though. The kit came with the carbon light chassis, I think it's the same one. Everything is still in the black box. I wont start putting together until I get my hop ups.
Thanks for the tip on the batteries, I will be using side by side packs. Where would you put the insulation?
Mike F is offline   Reply With Quote
Old 01-29-2003, 12:19 PM   #124
Regional Moderator
Old 01-29-2003, 03:25 PM   #125
ScottyP's Avatar
Default Outdoor bitumen foam setup
Hi all,
Here's a good set-up for a fast, flowing outdoor bitumen circuit. Fairly long straight and a couple of fast changes of direction.
This setup placed me second out of a strong field of 60+ cars on the weekend.
Front
40wt 2 hole piston
Yellow spring
Outer hole on arm and shock tower
Stock camber link position
5mm ride height
1mm droop
2 degree neg camber
1 degree toe out
Yellow sway bar
Rear
40 wt 2 hole piston
Yellow spring
Outer hole on arm and middle hole on tower
Upper camber link hole on hub and upper innermost hole on shock tower
5.5mm ride height
3mm droop
2 degree neg camber
2 degree toe in (standard)
Yellow sway bar
Other
Stratus shell
Full time 4WD - no one-ways
Orion Core stock
Rollout of 30.5
37 shore front and 35 shore rear
60mm rear tire, 58mm front tire
Orion 3000HV cells
Ambient temp 40 degress celcius +!!!!!!!!
Car proved very easy to drive and extremely manouverable through traffic. Worst part of the track for the car was the high speed sweeper (no one-ways) but the car was awesome on the fast direction changes.
Lack of testing time meant I could not try one-ways, but I would have liked to.
Keep the set-ups coming and bring on the TRF TA04!
Scotty
ScottyP is offline   Reply With Quote
Old 01-29-2003, 03:38 PM   #126
Regional Moderator
Thanks Scotty for the information.
Anyone have a set up for slightly bumpy, medium traction asphalt track. Long straights with a busy infield. rubber tires is what we use.
Thanks.
Old 01-29-2003, 03:59 PM   #127
PizzaDude's Avatar
Default TRF TA-04
Kit #49278
PizzaDude is offline   Reply With Quote
Old 01-29-2003, 04:05 PM   #128
PizzaDude's Avatar
Indeed when closely studying this pictures it looks like the 414 arm attachement blocks are being used on this one....
Old 01-29-2003, 06:40 PM   #129
TRF-Powered's Avatar
It also look like it's using SSG chassis!!!
TRF-Powered is offline   Reply With Quote
Old 01-29-2003, 07:33 PM   #130
Steevo's Avatar
I still think it looks just like a fully hopped up TA04 Pro.. Compare the two and see if I'm wrong.. Don't get me wrong I am a big Tamiya Ta04 Fan but I have to call it how I see it
Steevo
Old 01-29-2003, 08:02 PM   #131
ScottyP's Avatar
Sure it's a fully hopped up 04, but a very special one!
I know I can't get hold of an SSG chassis for mine and I have yet to see anyone successfully perform the roll centre mod on the arms.
Add to that all the blue goodies, worlds style front roll bar, alloy pulleys and all the other stuff we can't see and that's one great car.
Scotty
Old 01-30-2003, 02:43 AM   #132
badboy TC1's Avatar
Ey guys i thought this thread was scrapped! i cant find this thread for days. What happend? anyway Scotty P. nice set-up does it really work? also nice pics pizzadude
badboy TC1 is offline   Reply With Quote
Old 01-30-2003, 09:19 AM   #133
izzyracer's Avatar
Trader Rating: 27 (100%+)
Where did you get the spy pictures of the TRF TA04?
izzyracer is offline   Reply With Quote
Old 02-02-2003, 09:04 PM   #134
stratuskyo's Avatar
Exclamation .......
wow the 04r nsx was so fun!!!!!! the shock was so good!!!!!
stratuskyo is offline   Reply With Quote
Old 02-16-2003, 04:39 PM   #135
Regional Moderator
Default HELP
anyone know where I can get some Aluminium 5x9mm ball connectors (MC16 part#9805611) for the 04R as well as the Aluminium steering post that comes with the kit?
I broke mine tightening it
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
What settings? sho .21 Monster Trucks 1 03-16-2006 12:12 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
