Old 01-15-2003, 07:49 PM   #91
KINGZJ's Avatar
Send a message via AIM to KINGZJ
It makes a very big difference. That is why most people run the largest spur gear they can fit in their car. I do not know the physics behind it but it is a fact and has been proven on the track maybe someone with some engineering background could shead some more light on the subject
KINGZJ is offline   Reply With Quote
Old 01-15-2003, 07:55 PM   #92
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
or this mean that the higher the internal gear ratio the faster ??
imataquito is offline   Reply With Quote
Old 01-15-2003, 07:57 PM   #93
KINGZJ's Avatar
This would depend on th size of the pullies or gears!
Old 01-16-2003, 12:06 AM   #94
stratuskyo's Avatar
Default ... ~.~ ...
wow so many things to say but to me i still thinks that Ta04 may be slower at straight but i feel that if theres alot of turning i think that Ta04 is faster.......(TO ME)
stratuskyo is offline   Reply With Quote
Old 01-16-2003, 12:12 AM   #95
stratuskyo's Avatar
Default ...
erm what cover r u all using huh???
Old 01-16-2003, 12:13 AM   #96
stratuskyo's Avatar
Default ......
i wanna ask u guys whether is the raybrig nsx 2002 cover good??
Old 01-16-2003, 02:15 AM   #97
imataquito's Avatar
hm...... lets say bigger diff gear and smaller centre pulley
and then coupled with bigger spur to acchive the same ratio
Old 01-16-2003, 02:29 AM   #98
badboy TC1's Avatar
So you guys mean that our TAO4pro or watever TAO4 is far far to ever match a TRF414? so wat will i do with this kit...grrrrrr!!!
badboy TC1 is offline   Reply With Quote
Old 01-16-2003, 02:42 AM   #99
imataquito's Avatar
badboy!
u can try changing the front knuckles from left to right (c1 right c2 left )
for a more aggerasive stearing
Old 01-16-2003, 05:07 AM   #100
badboy TC1's Avatar
Thanks bro. can i ask whats the purpose of changing the turnbuckles where can i get the c1 and the c2? thanks again.....
Old 01-16-2003, 06:54 AM   #101
stratuskyo's Avatar
Default ...
to me i feel that not all 414s wins 04 i depends on the driver....the car....and the opponent.....
Old 01-16-2003, 06:57 AM   #102
stratuskyo's Avatar
Default ...
oh!!!! i just remember that i got a pro friend i tested the time of him when he was playing 04 the timing actually was faster than the timing whan he play 414....that means that he is better in 04.....
Old 01-16-2003, 06:10 PM   #103
badboy TC1's Avatar
stratuskyo: hey buddy thanks for that info...now im confidence even a little...i jas need to practice more on my driving and fix a little my pros set-up then we will see..hehehe...im so excited to race...i dont want to let go with my pro...i am contented with this car...but if anyone can convince me that the 414 is really much better than the TAO4...oh no!!! anyway we will see
Old 01-16-2003, 06:37 PM   #104
imataquito's Avatar
the c1 c2 is the plastic piece ur stearing turnbuckle is fixed to - the one that holds the wheels and universal joint in front .......
the one that can turn left and right ....
try switching them around .... u will get less stearing but more aggerasive and precise
yes the 414 is much better because it has some addjustability of a custom build car to boot .....
just add spacers or change spacer location or just use some creativity u will see some different setup... u can use... but it can also be a hassle because i have toooo much addjustability
Old 01-16-2003, 07:19 PM   #105
Aurra Sing's Avatar
Don't worry, your TA04 can beat any car as long as you are a better driver than the other.
Aurra Sing is offline   Reply With Quote
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
What settings? sho .21 Monster Trucks 1 03-16-2006 12:12 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
