Old 12-31-2002, 07:35 AM   #46
Regional Moderator
Send a message via AIM to Mike F
selection process - the only difference in the TA-04R NSX 2002 and the TA-04R chassis without the NSX body is just that, no body. Everything else is the same, correct?
Mike F is offline   Reply With Quote
Old 12-31-2002, 09:09 AM   #47
KINGZJ's Avatar
Send a message via AIM to KINGZJ
the older version of the 04r comes with a carbon altezza body and silver shocks. the new one comes with a nsx body and pretty blue shocks
KINGZJ is offline   Reply With Quote
Old 12-31-2002, 09:21 AM   #48
Regional Moderator
Cool, thanks KINGZJ. Oh, don't forget what I PM you about
anyone know someone interested in a Mission?
Old 01-01-2003, 01:28 AM   #49
Default SHORTY
Happy New Year guys! Mind if I join on the topic?
I'm currently using a TA04 Pro Blue collection -- extremely hopped up -- that ud look twice to make sure you saw an 04 and not a 414 I did have a TA04R before this but I gave it to my cuzin who just started the hobby. Both are almost the same, lil differences here and there but the same. Th e only reason I picked the Pro Blue was because I didn't like the wide profile of the Tub the R has. It keeps rubbing the side if you set low at 5mm ride height. So there.
I run it with the Tamiya 11Turn -- one hot motor alright!
I didn't use the droops screws, and my ride is better now than when I used them in my R. But mind you I use white and Blue springs.
A question you guys -- have you tried the 04 with the SS rear arms? Coz that's what I'm planning to do but wondered if anybody has tried it yet. I'm not sure how much shorter the wheelbase gets, but it could eliminate a lil understeer with no drawback eh? what do you guys think?
Also, is there any weight diff on the HARD ARMS and the stock ones?
May '03 be a good season for the 04!
Awesomatix Sanwa Trinity Tamiya
voodoo is offline   Reply With Quote
Old 01-01-2003, 12:02 PM   #50
SpeedTech's Avatar
Mike F,
We just got one of the new Raybrig NSX TA04R in stock and looking on the box I believe this TA04R comes with the new Tamiya shocks (the FL coated) 53471. These are suppose to be even smoother and a tighter seal against dirt. It's the same one they included in the new TBEVOIII kit.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-01-2003, 03:46 PM   #51
Steevo's Avatar
You bet they are. The shocks in the 2002 Raybrig NSX Kit are the best you'll find. They are soo smooth and the finish is second to none!!
Steevo
Steevo is offline   Reply With Quote
Old 01-03-2003, 09:03 AM   #52
stratuskyo's Avatar
Default ......~.~ ~.~........
erm everyone can put the settings here????? what i want is the setting of the car........ thanks.....
stratuskyo is offline   Reply With Quote
Old 01-03-2003, 10:30 AM   #53
Regional Moderator
Default Re: ......~.~ ~.~........
You'll get that a more stratuskyo. The problem is that these guys/gals are so passionate about the Tamya kits that they'll add some more to this thread then just set ups.
Steve I saw that you had some in stock, thanks.
Steevo - so the shocks that come in the 04R chassis kit are not the same but are threaded, correct.
Old 01-03-2003, 10:52 AM   #54
psycho's Avatar
Mike F
I believe all the current R kits come with the silverish gold colored threaded shock bodies. These are the smoothest shocks I have used from any manufacturer. I've been using the non threaded ones on my F1 cars for years.
stratuskyo
Here's the setup I'm running stock on carpet. It's pretty good, but I think I can still get more out of it.
Front:
5mm ride height (track requirement)
one-way
2mm of droop
yellow springs
40 weight shock oil with kit 2 hole pistons
Shocks stood up all the way (inside hole on arm and outside hole on shock tower - kit shock tower)
camber link in kit specified location
1.5 degrees of camber
1 degree of tow out on each side
blue swaybar
I'm not running the torsion rods
Rear:
diff fairly tight
4 mm of droop
red springs
Shocks in outermost position on lower arm and middle of shocktower.
1 degree of camber
kit included upright (toe setting)
yellow swaybar
Everything on the car is Tamiya except the tires, which are TakeOff CS27 with their inluded insert. I have the Tamiya Ferrari 360-GT body with the wing in the "low downforce" position. I'm running the kit shock towers as well. I hope this helps. I think this setup should work pretty well on fairly grippy asphalt as well.
psycho is offline   Reply With Quote
Old 01-05-2003, 03:46 AM   #55
stratuskyo's Avatar
Default hi!!!!!
hello everyone ....... i need all of you to tell me is it better the blue collection of 04 or the R?????tell me pls.......
Old 01-05-2003, 04:59 AM   #56
Default Re: hi!!!!!
Both are good kits. I had both of them but decided to stick with the Pro Blue. The diff could be that the R is lighter due to the Blue's FRP chassis - but the Blue has Aluminum Racing Steering and Front Aluminum Universals. I had to buy Turnbuckles for the Blue though, the R has them stock! The R has bodies (Altezze/NSX) while the Pro Blue is KIT ONLY.
Any choice would be great. get hte Carbon shock Towers, One-Ways and youre all set.
Old 01-05-2003, 06:08 AM   #57
lonestar1127's Avatar
hi guys any idea whether the front hub carrier for 414m2 be used for our 04??
lonestar1127 is offline   Reply With Quote
Old 01-05-2003, 08:23 AM   #58
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
If memory serves the 04R kit uses the same front hub carrier as the M2 (racing steering set with torque rods)
I did hear recently that they might start making these parts out of the reinforced material that we now see used in the rear uprites etc.
http://groups.yahoo.com/group/tamiyatrf/
madjack is offline   Reply With Quote
Old 01-05-2003, 08:33 AM   #59
04 hub carrier got two ball stud but the surikarn's 414m only had one ball stud on its hub carrier
http://photos.groups.yahoo.com/group...c=gr%26.view=t
On top of that the winning cars in tamiya world championship also using hub carriers that use only one ball stud....is there such are hop up???
http://www.tamiya.com/english/rc/twc...r_ex_large.jpg
http://www.tamiya.com/english/rc/twc...r_gt_large.jpg
Old 01-05-2003, 02:45 PM   #60
GKC
GKC's Avatar
Send a message via ICQ to GKC
They just cut off the part which holds the torque rods to save weight so it looks like what is in the picture.
GKC is offline   Reply With Quote
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
What settings? sho .21 Monster Trucks 1 03-16-2006 12:12 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
