Old 04-01-2004, 04:35 PM   #226
Dongskie's Avatar
Trader Rating: 44 (100%+)
Thumbs up My Ride:
I got my TA-04R just this February, here's what I got:
- Blue Aluminum Motor Heatsink
- Tamiya Titanium Turnbuckles
- Speed Mind Titanium Countersunk and Roundhead srew set for TA-04R
- Tamiya Super Stock Type-R Motor
- A good looking body
- See the Picture?
Bajer 1/5th
Dongskie is offline   Reply With Quote
Old 04-02-2004, 06:47 AM   #227
lem2's Avatar
Default my mods to the 04R
look!
modifications done:
lightened arms/larger motor vents/removal of abttery mounts, i just use tape!
lem2 is offline   Reply With Quote
Old 04-02-2004, 06:51 AM   #228
lem2's Avatar
Default my mods to my 04R
part 2
mods done:
lightened spur gear
you can see clearly the lightened arms and the rear hub, also notice the dual upper decks!
Old 04-02-2004, 06:54 AM   #229
lem2's Avatar
part 3!
Old 04-03-2004, 12:56 PM   #230
Default TA04 - Gearing
I am looking for different brands of spur and pinion gearing. I would like to stick to Tamiya gears, but it is hard to find, or is out of stock. I bought a robinson racing spur and pinion gear 120/38 in 64 pitch, but for some reason the spur gear did not align right to the mounting holes. Has anyone ran into this problem? Any suggestions on what brand of spur gear to use? Thanks in advance.
Dayten is offline   Reply With Quote
Old 04-03-2004, 01:49 PM   #231
Send a message via AIM to A-Ko
Kimbrough makes some decent ones. I had the same problem with Robinson.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 04-03-2004, 01:58 PM   #232
A-Ko Thanks for the reply. I'll try the kimbrough gears. You would think that there would be some sort of standard that all the spur gears would fit.
Old 04-03-2004, 02:59 PM   #233
RCGaryK's Avatar
I'm partial to HPI's spurs on my 04. They spin true, they're light, and they can take some pretty serious abuse. I first ran them on my HPI RS10GO oval car (yes, HPI made an oval car) and they were great on that car and I've been hooked ever since.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-03-2004, 09:55 PM   #234
RC Driver - Thanks for the info. I think that I might have better luck finding HPI gears at my LHS.
Old 04-04-2004, 04:49 AM   #235
rccardr's Avatar
Some Robinson gears fit perfectly- just make sure you get the 'standard' pattern (the ones made to fit 10th and 12th scale pan cars) and not one intended for a Losi or Associated off-road car or truck. I used a 115 Robinson machined gear on my TA04 GT3 car for 20 or thirty runs and it's still in excellent condition.
Duratrax gears from Tower are actually DuMor stock (they also used to do Trinity's gears). Very nice and the price is great. Like Gary, I've also had good luck with HPI purple spurs. Kimbrough spurs are also excellent.
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 04-04-2004, 05:58 AM   #236
I have found the atlas spurs to be extremly good wearing. After more than 20 runs they still look brand new!!!! I recommend trying them they will surprise you
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-04-2004, 06:13 AM   #237
lem2's Avatar
Default spur
the hardened TAMIYA .6 module spurs are really great!!! been using it for almost a year and looks brand new. Although they only come in 83tooth and tamiya's .6module is only from 18to 27, and you have to lenghten the mounting holes for the motor to make some of the pinions to reach the spur.
*.6 modules are almost like 48pitch
Old 04-04-2004, 11:16 AM   #238
Thanks for all of your suggestions. I'll try those gears out.
Lem-Thanks for you suggestion, I am trying to keep my car TCS legal so I can't do any cutting on the motor mounting holes.
Old 04-04-2004, 12:08 PM   #239
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Thumbs up TA04 sale link
For fans of the TA04 here is a link to a chassis for sale.
http://www.rctech.net/forum/showthre...908#post803908
madjack is offline   Reply With Quote
Old 04-06-2004, 05:37 AM   #240
badboy's Avatar
Trader Rating: 14 (100%+)
TA04 Racing Stabilizer Set (rear)
Can I use this in front. Is this the same Stabilizer set that came with the TA04 TRF Kit? I can't find one that says (front) in my LHS. Thanks
slow is fast . . .
badboy is offline   Reply With Quote
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
What settings? sho .21 Monster Trucks 1 03-16-2006 12:12 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
