Old 03-15-2004, 08:03 AM   #211
Default Stabilizer on TA04 TRF
I notice that both the front and the rear sway bars don't seem to do much on the TA04 TRF. Without the shocks connected, when you lift up one arm, the opposite arm doesn't lift up at all.
I don't see any binding on the suspension arms. All arms move smoothly and drop on it own weight. Am I missing something?
Thanks.
Supra66 is offline   Reply With Quote
Old 03-15-2004, 08:16 AM   #212
rtypec's Avatar
There's a much improved stabalizer set available for the TA04, unfortunately, I don't have the part number. The newer setup provides a more direct link with the suspension.
rtypec is offline   Reply With Quote
Old 03-15-2004, 10:26 AM   #213
psycho's Avatar
The part# would be much appreciated! Is this the set for the TB02?
psycho is offline   Reply With Quote
Old 03-15-2004, 10:39 AM   #214
rtypec's Avatar
Oh man, I guess the part number would be somewhere on tamiya japan's english site under one of the month's new releases. I used it for my world's TA04 and gave the stabilizer a more direct feel with the arm...<alt-tab to search>....(some funky elevator musak)....okay back, here it is:
Item 53676 TA04 Racing Stabilizer Set (Rear)
Old 03-15-2004, 04:54 PM   #215
Thanks for the reply. If you ever wonder how they look like,
this is what the package look like...
My next question is, will it be better off to change the sway bar mounted on the upper desk to the more conventional way like the regular TA04?
Old 03-15-2004, 05:18 PM   #216
rtypec's Avatar
The WCR style upper deck stabalizer mount is good for the TA04, coupled with the set that you pictured, you'd be good to go in the stabalizer department.
Old 03-30-2004, 04:32 AM   #217
Default The Uhuru of Set-ups
Okay, I need help
I run:
TA04, Monster Horsepower Pro and P2k2pro
The other fellas at the track seem to be shy in sharing their gear setups, coz they just be kicking my @sk with the same chassis/motor.
The track is semi-technical, a little of both worlds meaning a few long bends, 2 straight, and tight in-field.
Question 1 - What spur/pinion do I need to go super fast
Question 2 - What spur/pinion do I need to have Rhino-like torque
Much appreciated, hurry, the car is pointing at the wall
Sharp, thanks
Punkynutt is offline   Reply With Quote
Old 03-30-2004, 06:22 AM   #218
gcooper's Avatar
Default Re: The Uhuru of Set-ups
Originally posted by Punkynutt
Okay, I need help
I run:
Sharp, thanks
What ratio are you running now and how long is your track?
Are you running a ball diff setup or double 1-way?
Coop
gcooper is offline   Reply With Quote
Old 03-30-2004, 06:51 AM   #219
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
i ran My 04 pro 112 and 43 pinion. So its 5.5 ratio. 23t stock motor.
But still loose 2 laps with the yoks.
Any sugguestion?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 03-30-2004, 07:42 AM   #220
Punkynutt : try this for the monster stock. 120/35
Kreator1 : try 112/45
bosschick is offline   Reply With Quote
Old 03-30-2004, 07:46 AM   #221
Which 23T are you using right now ??
Any sugguestion?
Anthony Yuen is offline   Reply With Quote
Old 03-30-2004, 09:12 AM   #222
KREATOR1's Avatar
Anthony Yuen .Im using the xenon MoMo griffon 23turn motor
bosschick : are you sure the 04 can take that low ratio?u try it before? how the motor heat?
Old 03-30-2004, 11:19 AM   #223
psycho's Avatar
Punkynutt
I'd stick with the Monster motor. It is a high rpm motor, so you want to gear it much higher than the P2K2. bosschick's suggestion should get you in the ballpark. That's 7.31:1 which is a good place to start. You should, however, always gear for the track. An easy way to do that is to watch where the speed tops out on the longest straightaway. If you top at midway down the straight, you should increase the pinion size until you top out just as you're letting off the throttle at the end of the straight. If it feels like you have more speed in it, go down a tooth and test again. Once you get it set, you won't vary it by much as the track layout changes. You may need to change the gearing slightly depending on what you need for the rest of the track, though. Also, it's a good idea to experiment with different spurgear sizes since you can get a finer gearing adjustment by switching both pinion and spur than you can by only changing the pinion. For example, the 120/35 gets you to 7.31:1 where a 112/33 gets you to 7.23:1 compared to 7.11:1 if you go up one tooth with the 120 spur. You can calculate the gear ratio with this formula:
<spurgear teeth> / <pinion gear teeth> X <internal transmission ratio> = final gear ratio. On this car, the internal ratio is 2.133. I hope that helps.
Old 03-30-2004, 09:40 PM   #224
Originally posted by psycho
Punkynutt
Thanks Psycho and bosschick
This will help tremendously...........I'll get a few more pinion sizes
Old 03-31-2004, 08:09 PM   #225
Entropy's Avatar
Hi guys
I'm wondering whats the lightest you've ever got your TA04
Also please list the parts that you used to achieve it, I use a TRF spec TA04 with a lightweight tub chassis myself.
thanks
Entropy is offline   Reply With Quote
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
What settings? sho .21 Monster Trucks 1 03-16-2006 12:12 AM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
