Old 12-22-2002, 09:07 PM   #1
xray racer's Avatar
Trader Rating: 22 (100%+)
Default xray alloy shocks
what is the difference between the alloy and nylon shock bodies???
which is better
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 12-23-2002, 03:10 AM   #2
university_dave's Avatar
Well I've changed to the alloy bodies bacause the first time I rebuilt the plastic ones they had warped so much I couldn't get the caps back on.
Having said that, the seals at the bottom don't seem to be working with the alloy ones and they leak like a sieve...
university_dave is offline   Reply With Quote
Old 12-23-2002, 06:07 AM   #3
I`ve run the Serpent/X-Ray shock on 1/8 on road on down to 1/10,and have never had a problem with the plastic bodies or found a reason to switch to the aluminum ones.
saints1115 is offline   Reply With Quote
Old 12-23-2002, 08:21 AM   #4
dtm's Avatar
Send a message via ICQ to dtm
Plastic ones are fine! unless you take a direct impact on them...then they break up in two! However, unless they have improved the finish inside the bodies from Serpent times......I would stick with the plastic. Serpent alloy bodies are renown for being "not smooth"........
dtm is offline   Reply With Quote
Old 12-23-2002, 05:39 PM   #5
Neil Rabara's Avatar
The alloy bodies are good replacements when the plastics warp or sustain irrepairable damage as a result of a direct impact. Just keep in mind on a hot day outside, the track temp may deform the shock bodies causing inconsistent piston action. I haven't had any problems with the alloys, my plastic shocks leaks more.
Neil Rabara is offline   Reply With Quote
Quark 4T BL motor, rc18t xps esc, mlst shocks, and xray alloy motor mount. rschoi_75 R/C Items: For Sale/Trade 2 09-08-2011 11:28 AM
Corally RDX alloy shocks {VIC_RDX} Australia For Sale/Trade 0 04-10-2007 02:09 AM
HPI Savage alloy shocks A Ilievski Australia For Sale/Trade 0 02-11-2007 03:20 PM
Kyosho fw 05t plus alloy shocks stevenc Nitro On-Road 6 01-05-2007 11:45 PM
Pro4 shocks and alloy hop ups Rogier R/C Items: For Sale/Trade 8 01-03-2006 06:26 AM
SEO by vBSEO 3.5.0
