Xpress Arrow AT1
#796
We had the VIC state titles last weekend at GRCR. It's a small tight indoor asphalt track, and I managed to put my AT1 into 2nd in the 13.5 stock class. Another AT1 finished 3rd in Mod. Other than throwing a drive pin during seeding before I could complete a lap, the car was flawless.
#797
Any major advantage of using a diff in the front over the standard spool in terms of performance and handling of the car given everything else remains equal?
#798
R/C Tech Elite Member
So you are a shorty convert now?
#801
#803
#804
#806
I recently picked up one of these and had a couple of questions. When I measure the rear toe it’s never even left to right. Electronics side seems to be .5deg more. Also when setting ride hight one side seems to need more preloaded on the spring. Tried to see if I had tweaked the chassis while assembling the car but it lays flat and nothing stands out.
#807
#808
I am using Xray springs. I will keep looking into it. Thank you.
#809
I'd like to use the springs and the X4/23 shock. Looks like an extra long rod end is needed.
Anybody figure a way to do this?
Thanks.
Thanks.
