Roche Rapide F1 EVO3 >
Like Tree112Likes
Old 04-06-2022, 09:48 AM
RocheRCUSA's Avatar
Default Roche Rapide F1 EVO3
Announcing the newly re-designed Roche Rapide F1 EVO3 car kit. Major features include-
  • New design graphite main chassis, rear pod plate, front lower arm, caster adjust plate, top deck, chassis brace
  • New design aluminium rear bulkheads and lower pod plat with centering pins
  • New design aluminium motor mount and rear bulkhead with plastic axle ride height adjusters. Red/Black two tones anodize.
  • New design 7075 aluminium floating servo mount and main chassis, lower servo position.
  • New design graphite multi-flex top deck, adjustable chassis flex by special tweak free screws. Center damper positions adjustability on top deck.
  • New design center pivot system. High / lower pivot position adjustability.
  • New DVS-V3 center damper. Quick rear droop adjustment.
  • New 7075 aluminium easy adjust side spring holder.
Car kit will be available in two forms - both available Mid April 2022
  • 152022 Roche Rapide F1 EVO3 1/10 Competition F1 Car Kit
  • 152023 Roche Rapide F1 EVO3 1/10 Competition F1 Car Kit, USA Spec
RocheRCUSA is offline
Old 04-06-2022, 12:56 PM
fat500's Avatar
Trader Rating: 51 (100%+)
I can't wait to see how they made an amazing car better
astgerma52sp likes this.
fat500 is online now
Old 04-07-2022, 04:31 AM
Trader Rating: 88 (100%+)
Can't wait for this to come out.
MUDVAYNE is offline
Old 04-07-2022, 03:34 PM
fat500's Avatar
Hello......I Need this car....Now please........Thank you.....
Old 04-07-2022, 05:08 PM
TheBeave's Avatar
Would love to see some pictures of the car other than the servo and rear pod.
MC Hamilton likes this.
TheBeave is offline
Old 04-10-2022, 06:31 PM
Rastaracer's Avatar
looking forward to it.!
Rastaracer is offline
Old 04-11-2022, 10:30 AM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Dan is offline
Old 04-11-2022, 11:22 AM
shadowracer24's Avatar
Really like the changes they made to the car but really wish they had done the same to the battery mounting system. Still a weak spot. Oh well at least the system I made will transfer over easily.
shadowracer24 is offline
Old 04-11-2022, 11:42 AM
So here's the $64 question. Will we be able to take the new pod and put it on the EVO 2?
MUDVAYNE is offline
Old 04-12-2022, 01:51 AM
Your ideas are great, I'm looking forward to your results
homecare2022 is offline
Old 04-12-2022, 05:34 AM
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I asked Max Ma of Roche and he provided a list of parts that would need to be swapped in order to just change the motor mounts from a Evo2 to Evo3. it isn't as simple as buying two motor plates.
1x 210274 Rapide P12 EVO2 Center Pivot Mount Spacer Set, 0.5/1mm <-- Evo2 optional part that you might already have
1x 210279 Rapide F1 EVO3 Aluminum Center Pivot Ball Mount
1x 210280 Rapide F1 EVO3 Aluminum Lower Pod
2x 210282 Rapide F1 EVO3 Aluminum Motor Mount / Rear Bulkhead
1x 220218 Rapide F1 EVO2 Graphite Rear Pod Plate <-- you should already have this
1x 220281 Rapide F1-EVO3 Graphite Chassis Brace
finally you'd need the axle holder -- not sure which best works depending upon ride height goals--
240175 Axle Height Adjuster, OP Version (0.75)
240176 Axle Height Adjuster, OP Version (1.00)
240177 Axle Height Adjuster, OP Version (1.25)
NutDriver likes this.
hanulec is offline
Old 04-12-2022, 08:22 AM
Awesome, thank you for this info!
MUDVAYNE is offline
Old 06-17-2022, 11:30 AM
Dan
Dan's Avatar
Could anyone tell me the length from the bottom of the diff side (where it meets the axle bearing) to the outer edge hex hub mount? (not counting the axle threads)
Dan is offline
Old 06-17-2022, 04:00 PM
I have an Evo2, and my son has an Evo3 - I'm not sure why you would want to swap the new pod to an Evo2. Possibly the ride height pills if you don't already have Evo2 option parts? Also on the Evo3, you have to unhook the side tubes to adjust the side spring tweak, as the adjustment is now on the top, and the spring carriers are very different.
I did put the floating servo mount on my Evo2, as well as the new top deck - I think it removes several areas that can cause temporary chassis tweak. FYI - the servo mount will move the servo forward about 5mm.
belewis01 is offline
Old 06-17-2022, 06:59 PM
Typeone's Avatar
Trader Rating: 50 (100%+)
Plan on getting one of these. What spare/option/tuning parts will i need. Also does the xray gear diff work in this car? Also do most bodies fit on this chassis?
Typeone is online now
