Roche Rapide F1 EVO3
#227
Rear spacers
Just picked up an evo3 used and was looking at the manual. It shows 1mm spacer on the gear side and 2.5 on the other side. When i do this my wheel will not clear. How many spacers are you all using?
#234
Looking for 340187
Does anybody have a lower pivot or know where I can get them? It seems like every shop is out.
#236
Update 340187
Just spoke with side piece and this part will never be made again. Is there an option?
#237
R/C Tech Elite Member
#238
#239
For anyone still looking for an alternate to the lower arm problem I can confirm the Krazed Builds ones fit the Evo3 with proper camber adjustments.
The Evo2 and Evo3 use the same upper CF arms and lower alloy chassis mount pieces.
The Evo2 has a different camber plate and lower arms.
Unknown since never having an Evo2 but after some homework and test parts Ive been told they work on the Evo3.
So if you need lower arms on an Evo2 and use Krazeds you will need to update your camber plate to the #320261
Probably a worthy update since it widens the track width.
Evo3 drops right on.
Krazed will have inventory in the next couple days, they are cutting more.
