Old 12-21-2002, 05:13 PM   #1
skibum989's Avatar
Default Digital servo = Horrible Battery Drain?
Sup guys! I wanted to hear your opinions on putting a digital servo in my XXXS with a 10-double. I know the battery drain of a digital servo isn't that bad with a stock motor, but will I have problems with dumping if I put a digital in now?
skibum989 is offline   Reply With Quote
Old 12-21-2002, 06:32 PM   #2
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Lightbulb
If you are worried about batterys dumping with the digital servo...then I would get a digitial one with 6V vice 7.2V I.E. a Futaba 9550 vice a KoProPo 2123
both of them are outstanding servos..but the 2123 is a tad bit over kill in my book
Hope this helps a little
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-21-2002, 07:53 PM   #3
dtm
dtm's Avatar
Send a message via ICQ to dtm
A digital servo will drain more than an analogue servo.........but the battery drain from ANY servo is insignifcant compared to your motor! You have to put things into perspective sometimes!
dtm is offline   Reply With Quote
Old 12-21-2002, 08:15 PM   #4
Telengard's Avatar
Just run some of the new 3300Ni-MH and you shouldn't really have any problems dumping in a race....
Telengard is offline   Reply With Quote
Old 12-21-2002, 08:26 PM   #5
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Digital servos do not drain that much I ran 45minute to 1 hour mains running 2 digital servos in my 1/8 buggy. If you are gonna dump because of your servo then I would look elsewhere for your problems.
KINGZJ is offline   Reply With Quote
Old 12-21-2002, 09:34 PM   #6
I run 2400 nicads & running Futaba 9450 digital servo.I haven`t noticed any significant performance loss or battery dumping during a race.
rcconcept is offline   Reply With Quote
Old 12-21-2002, 11:11 PM   #7
popsracer's Avatar
Default Not a consern
Ski Bum;
Only time I might want to go analog is in an Electric spec class that only allows 1500-1600mah battery packs.
Using any Digital servo should be of no concern, Nitro or electric. All of my cars (8) have them in at least the steering.
popsracer is offline   Reply With Quote
Old 12-22-2002, 09:49 AM   #8
skibum989's Avatar
Thanks guys! The servo I plan on putting in is a Airtronics 94757 Digital (6.0V). I run Sanyo 3000HV's, so dumping shouldnt be a problem.
Old 12-22-2002, 10:04 AM   #9
popsracer's Avatar
Default Digital servos
skibum989;
I don't know the specs of the Airtronics 94757 Digital (6.0V), but go for the fastest one offered. You will really love the way the car drives with a High Speed servo.
Old 12-22-2002, 10:29 AM   #10
skibum989's Avatar
It's a pretty fast one at 0.07 sec. It has 115 oz/in. of torque too, with dual ball bearings and all metal gears! (ok, ok, im getting kind of corny)
Old 12-22-2002, 08:36 PM   #11
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
The 6.0volt/7.2volt is just what voltage was used to get the specs for the servo. If your running 6cell, it'll run at 7.2v regardless...
pimpedaccord is offline   Reply With Quote
Old 12-22-2002, 09:39 PM   #12
dtm
dtm's Avatar
err....not quite true!!
Old 12-22-2002, 09:51 PM   #13
Suspended
Yeah, the servo will only run at 7.2 V if it is a fet servo with a forth wire attached to the speedo. All other servos will run at 6.0V when in a car with an ESC. The esc only sends 6.0V to the reciever so it doesnt fry the reciever.
Rick E. is offline   Reply With Quote
Old 12-23-2002, 05:23 PM   #14
skibum989's Avatar
No, there is no fourth fet wire, so it runs on 6.0v. Thanks again for the help!
JR 9100T digital servo / XP (ACE) 1015 digital servo SCUBA STEVE R/C Items: For Sale/Trade 11 08-18-2010 12:28 PM
Tekin Battery Doctor 8.0 & Futaba S9452 Digital Servo limbohz R/C Items: For Sale/Trade 10 05-12-2008 09:57 AM
Ice Charger, Tekin Battery Doctor 8.0, Futaba S9452 Digital Servo, Novak 13.5 limbohz R/C Items: For Sale/Trade 29 05-06-2008 12:15 PM
receiver battery drain / failsafe problem Tooned G4 Rookie Zone 2 09-21-2004 11:42 AM
Digital servo / battery votage MarNaDaKi Electric On-Road 3 03-10-2003 02:26 PM
