charging 1/12th scale receiver packs
gidday,
I was wanting to know what current you charge your 5 cell gp 160mah receiver packs at? My charger has a limit of 0.5amps and gp recomends 0.16amps on there spec sheet. What do you guys do about this? Also is it correct to have a switch for the receiver pack? Thanks for the help Mike |
Originally Posted by ixlr8nz
gidday,
I was wanting to know what current you charge your 5 cell gp 160mah receiver packs at? My charger has a limit of 0.5amps and gp recomends 0.16amps on there spec sheet. What do you guys do about this? Also is it correct to have a switch for the receiver pack? Thanks for the help Mike You can use a switch on the reciever pack or take the plug in and out of the reciever. Remember to remove or cover up the switch on the esc. |
Thanks very much. I will try both your tips.
Mike |
