Team Orion Advantage w/ LiPo or Team Much More Cell master?
I'm looking to get new charger and I wanted to know wich is better the Team Orion Advantage w/ LiPo or Team Much More Cell master, and why?
RH
RH
Any opinons?
RH
RH
I would personally grab a Much More Racing Cell Master. I'm not sure about the newer lipo version of the orion advantage, but I remember thre original one having a pretty non linear charge current. It would fluctuate pretty easily. The Cell Master is realllllllly linear, and gives a better overall charge. I personally dont like the menu's int he advantage charger either.... The cell master is pretty easy.
I've been using mine along with their heatsink and warming tray and it's been working awesome for me. I use the heatsink during charging because it equalizes cel temperature while charging, then if I peak to early before a race I drop the battery into the warming tray. It seems like the internal resistance int he battery is almost directly related to the temperature of the battery. They need to be warm if you want some rip out of it.
-Korey
-Korey
I have an Advantage and it works great. The Orion and Much More chargers are essentially the same unit with different software.
The Orion is little cheaper, uses a magnetic temp probe and has a very basic motor run-in feature.
The Much more has a better menu system, finer adjustments, a std temp probe and supports an option batter warming tray.
They are both great units. I would say that if you need the motor run-in and the Orion menu system doesn't bother you go with it, otherwise you would probably be happier with the Much More.
Mark
Mark
I know the new Advantage has a step charge feature which is supposed to be good and is used by some of the top sponsored Orion drivers.
Skiddins
I don't know much about the Much More charger.
Skiddins
Mark
Mark
Ok well it looks like I'm heavily considering the TMM Cell Master. I was wondering, who has the best price on the Cell Master.
RH
RH
