Old 04-05-2006, 02:01 AM   #1
viet_mafia's Avatar
Default Problem with 3PK?
Hi, I just bought myself a 3PK radio recently and I noticed that when i go into the throttle adjuster menu it is ALWAYS on 20% brake/reverse or around there. All of my EPAs and throttle adjustments and everything are on neutral/0 but this throttle adjuster reading is always around 20% brake/reverse!
I just wanted to know if this was a normal thing? Or if its a problem how would i go about fixing it?
Thanks guys
viet_mafia is offline   Reply With Quote
Old 04-05-2006, 03:01 AM   #2
I'm not to familar wth that radio. but you could try, once it is set turn your radion off then back on. this might lock the setting in. I noticed when I had my 3pj I had to do this.
cyrrus is offline   Reply With Quote
Old 04-05-2006, 03:25 AM   #3
LasagnaCat's Avatar
Trader Rating: 134 (100%+)
Send a message via AIM to LasagnaCat
If you look in your manual, there's a section on how to recalibrate the steering and throttle.. I'd try that first. Also, have you tried resetting the model memory?
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-05-2006, 11:29 AM   #4
Save a model in the memory, Change it to the setting you require then press end twice.
casper7 is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 07:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
SEO by vBSEO 3.5.0
