Schumacher Eclipse 4
#46
About a Al chassis plate would be undesired on Asphalt and CF is not included in the kit:
Hmm, many other classes have Al chassis plates and survive, At least you have the CF option at the E4 (Awesomatics doesn´t but they also run it on asphalt.)
Flex affects handling - yes, but the E3 and E4 can be easily adjusted by the top deck mounting points that you use.
Best regards Erhard
Best regards Erhard
#49
Ran a half dozen packs in mine yesterday. Car is immediately consistent and ready to drive. A minute but noticeable improvement over my 3. In our Outlaw GT12(25.5 2s) class we use a spec Gravity tire so I'm using the Core spool hubs from my 3 with the spacer.
I'll need to get some parts to upgrade my 3 as a loaner/backup car.
#50
Does anyone make a taller/more robust front battery stop for the Eclipse 4? Our track is small and tight. One tap on the inside rail in a high speed corner can send you head on into the outside wall at full speed and cause the battery to jump over the thin piece of CF. I have had that happen twice now. Once it knocked my ESC loose from the mounting tape. I was wondering if anyone made a taller piece to prevent that from happening. I wish they hadn't incorporated the damper mount into the battery stop, otherwise, I would just mount several of those pieces together to make a thicker version. I would love to hear what others may have done to solve this. Or am I the only one that hits things?
#55
#56
#60
Hi can anyone tell me the correct part for eclipse 4 carbon fiber chassis plate?
