FT TC4 Aftermarket parts
what is probably the best aftermarket maker of FT TC4 parts? And can someone give me a list of makers of FT TC4 parts
i know that 3Racing has some hop ups for the TC4, are there any others?
Any aftermarket company that makes aftermarket parts will make something for the TC4. All depends on what you want.
Best performace stuff would probably be IRS.
TC4 parts.
I never found any good hopups other than the Sqaure aluminum spur gear mount. 3racing towers flex and IRS aluminum imput shafts were off, so I gave up on them. I loved my Losi JRX-S shocks on it and they were a direct fit.
3Racing Titanium axles/driveshafts
Lunsford hindgepins/susppension pins
I have been making carbon fiber drive shafts for the TC4 (other shaft drive touring cars as well). Pretty trick and they weight in at 5.5-6g veruss 13g for the stock shaft. In my opinion, the easiest way to drop lap times. PM if interested or click on the link under my signature for more details.
Erik
Erik
I wouldn't consider anything made by 3 Racing a hop up...more like a down grade. The C/F is thinner and of a lower quality. Best bet is to skip it.
The very, very ealry IRS input shafts (about 5 years ago in the early days of the TC3) were a tad off. I haven't had any problems with them since (I ran them for 3 years in 2 TC3 and currently run them in my 2 TC4 and they are factory perfect!!).
I also had an IRS input shaft and I would pass again. Their alum. diff halves are very nice, but install their pin cushins on the dogbones to protect them.
Erik
Erik
Titanium Racing make parts for the TC4, they are always of the highest quality.
http://www.titaniumracing.com/produc...asp?menuid=218
Yup, IRS input shafts suck big donkey nuts. One thing I did with my first TC4 was this...get the IRS pin cushions and Schumacher drive shaft blades. What you do is fit the cut the plastic from the pin cushions down so they just fit the drive shaft (no plastic is exposed outside the drive shaft). Then you install the schumacher drive shaft blades. Even less wear than with the normal pin cushions.
I found the Square RC delrin diff outdrives stopped the breaking the plastic ones seem to be prone to at the front. Can be used for 19t, possibly mod too. The IRS composite dogbones will shed some weight from the transmission, but make sure you put a tiny drop of glue to hold the pin cushion in place or they will slide off-center (mine did).
If you haven't got it already, it's worth getting the AE VCS2 shock kit - makes rebuilding much, much easier.
