Old 03-27-2006, 02:12 PM   #1
Default Peak Dynasty V2 19T
Hi, I have a problem with a V2 19T Spec.
I kind of hit the wall and it stopped working, I changed the endbell and it worked again, wierd thing is the LED in the endbell was working ok.
Anyone have any ideas what has happened?
PS The hit blew up my ESC (Cyclone too), expensive mistake.
markb78 is offline   Reply With Quote
Old 03-27-2006, 03:00 PM   #2
Andrew Gray's Avatar
My guess is this, if you smacked the wall fiom the side, you probably bent the brush tubes so the brushes are hung up and popped out the bearing. If you get a steel rod that is the same diameter as the inside of the brush tube you can probably straighten them out so it will work again.
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 03-27-2006, 03:01 PM   #3
rocketron's Avatar
Trader Rating: 16 (100%+)
you should check to see if the brush tubes are shorted to the endbell. you put on another endbell and the motor ran - right? if so thats all i could imagine - sounds like a costly hit for sure..........
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Peak Dynasty V2 Motor jim beam Australia For Sale/Trade 2 06-02-2006 03:37 PM
Peak Dynasty V2 v0rtex Australia Wanted to Buy 0 01-30-2006 05:21 PM
Peak Dynasty 19t Motor jzone Electric On-Road 59 03-10-2005 04:12 PM
Peak Dynasty 19T motor D_Ames Electric On-Road 2 12-30-2004 11:07 PM
peak dynasty V2 19t??? stumper Electric On-Road 13 08-05-2004 12:59 PM
SEO by vBSEO 3.5.0
