Old 03-24-2006, 04:22 AM   #1
Default Guge Wire for GTX
I recently just purchased a Novak GTX, and I really like it a lot. However, I would like to change the color of the 14 gauge wire to blue. Can anyone please help me on where to get this at?
Also, if there all the same color, how can I tell EASILY if it goes to the motor, battery, or if its negative or positive.
LANCEisaCRACKER is offline   Reply With Quote
Old 03-24-2006, 04:38 AM   #2
Emaxximuss78's Avatar
You should be able to ge the wire at any good hobbey store.
I thinck tower allso has wire. you want the good silicone wire. Either 14 or 12 gauge. as for telling witch wire goes to the batt or motor. You should be able to get a manual for it off the manufactors web site.
hope this helps
Emaxximuss78 is offline   Reply With Quote
Old 03-24-2006, 04:49 AM   #3
AngryAsian's Avatar
When you resolder the whole thing together again, slip a small bit of heat-shrink over each wire at the motor side. get heat-shrink in the original wire colours and you'll be fine.
Looks very "Pro".... If you're using 12g, then be sure to liberally tin the wire first. You may need to shave down the end of the wire to get it to fit onto the tabs on the esc.
Do one wire at a time and you'll be fine.
AngryAsian is offline   Reply With Quote
Old 03-24-2006, 12:05 PM   #4
ICEMAN's Avatar
12 gauge is what most use
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 03-24-2006, 12:10 PM   #5
tbeardmore's Avatar
if you are going to install in a 12th scale use 14g..... it's lighter!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-24-2006, 01:09 PM   #6
Novak sells 14G wire in blue. Check their site.
Lano is offline   Reply With Quote
GTX 16 g wire ?? gurumods Electric On-Road 5 02-27-2007 08:10 AM
Wire Fuzzy Electric On-Road 6 03-08-2005 11:32 AM
Ok so what's the best 4 wire ESC? Mabuchi540 Electric On-Road 16 11-27-2004 09:34 AM
What Wire Do You Use??? 2BAD4ALL Electric On-Road 7 11-27-2004 12:11 AM
Anyone know where to buy "26 Awg, 22 Stranded Wire" or typical antenna wire? Thanks Shrub Electric On-Road 9 04-16-2004 04:57 PM
SEO by vBSEO 3.5.0
